Results 1 to 8 of 8
Thread: servicing the rear air system
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    now before i start i do suggest you take the truck to the dealer to pinpoint what is needing replaced after that you can follow my how to
    total time it takes is about a hour to 2 hours depending how fast you work
    first find the tools you need to remove the battery cable and the panel over the area where the rear air is at
    first in order to remove the big panel over the rear air you have to remove a few other trim pieces just look at the pics and you will be able to do it IMG_0596.jpgIMG_0595.jpgIMG_0598.JPGIMG_0597.JPGIMG_0600.JPGIMG_0601.JPG i didn't get a pic of the rear tweeter and urpa display but just gently pull on the side near the window and it will come out after you have removed all of the trim peices and the panel you will see this
    IMG_0594.JPG and i will tell you which is which with pics
    this is the module that works the rear air so if you have a possible battery drain along with either no temp or vent control then this will possible need replacing but if you have no fan control then the module near the blower is the one to replace if everything else works
    and there is two acuactors one near the front and near the rear
    the front one works the vent control the rear works the temp control but both are the same but here is a couple of pics of them
    IMG_0605.JPGIMG_0606.JPG now before you reinstall the panels in place here is how to recalabrate the system after you reconnect the battery cable turn the key to run for 2 mins then turn off then start the truck then you will be good to go.
    Mar 2011
    speedwell tn,
    11,884
    Re: servicing the rear air system
    i'd like this to be made into a sticky please
    nelson480's Avatar
    nelson480 is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade Red Raven
    Nov 2011
    71
    Good to know, Have to do it soon for my dads 02
  5. #4
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,299
    Nice post. Added to the newly created FAQ thread.
  6. #5
    Freeflyer is offline Cadillac Owners Member
    Automobile(s): 2000 Escalade, 2006 CTS, 2008 SRX
    Jan 2010
    Georgetown Texas
    26
    I have a 99 and the rear a/c blows and the heat works but no cold. I was told that it was the expansion valve. Is there something easier to check first before I tear this completely apart and bust the freon lines?
  7. #6
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Freeflyer
    I suggest removing the covers to get access to the system to make sure that the actuators are responding to the controls(this is how mine did but it was cold air) most times if you have ac in the front the rear should too as they both use the same compressor
  8. #7
    Jan 2010
    Georgetown Texas
    26
    Thanks, I will report back of what I find.
  9. #8
    Mar 2011
    speedwell tn,
    11,884
    I did a how-to for servicing the rear air system it is under the FAQ sticky
  • You may not post replies
