EVAP Error Code
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, EVAP Error Code in Cadillac Escalade Forums; My EVAP code is continuing to come on, the first two times it happened, I replaced the Vent Valve and ...
    djais1801's Avatar
    djais1801 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 EXT Sable Black
    Feb 2011
    NJ
    47
    246
    EVAP Error Code
    My EVAP code is continuing to come on, the first two times it happened, I replaced the Vent Valve and updated bracket. It was good for about 2 months, and now it is coming on again. We reset the light 2x and on the 3rd time, we blew out all the lines to make sure no dirt/dust was in the lines. I don't live in a dusty area, and don't offroad. Is there possibly a control module for the EVAP that could be faulty? My truck is an 03 EXT with 105k.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: EVAP Error Code
    if you can get the code and post it i might be able to help.
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    Re: EVAP Error Code
    Sorry...it's the same one that keeps coming up P0446
    Mar 2011
    speedwell tn,
    11,884
    Re: EVAP Error Code
    http://www.obd-codes.com/p0446 here you go read this and see if it helps.
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    Re: EVAP Error Code
    thank you Cadillac Man...I will give this to my mechanic.
    ohsixext is offline Cadillac Owners Member
    Automobile(s): 06 EXT
    Sep 2011
    47
    Re: EVAP Error Code
    How do you find out the code? My check engine/service engine light came on, but when i brought the truck in for an out of province inspection and the light was on then, the mechanic said it was evap but he reset it because It was running fine and I didnt want to deal with it. 3 weeks later, it came on again.
    Sep 2011
    47
    Re: EVAP Error Code
    How do I reset it? Would it work if I disconnected the battery?
    Mar 2011
    speedwell tn,
    11,884
    Re: EVAP Error Code
    you can go to auto zone and have them connect a obi-2 reader and use it to clear the codes but i do suggest you fix the issue before you clear the codes or it will be back.
    Mar 2011
    speedwell tn,
    11,884
    Re: EVAP Error Code
    and fyi there is no way to clear the codes by disconnecting the battery now i know i have tried i have a maf code that pops up ever so often i guess the sensor needs to be replaced.
    Sep 2011
    47
    Re: EVAP Error Code
    the downfalls of canada no autozonene or kensun.com shipping. I have the day off tommorow im sure I will find a parts store around here that can help me out.
    Mar 2011
    speedwell tn,
    11,884
    Re: EVAP Error Code
    good luck in finding a parts place i hope you figure out the true source of the problem.
    Sep 2011
    47
    Re: EVAP Error Code
    I got the light cleared. The code that came up was the vent valve solenoid. With the power of this forum I swear I knew more about it then he did. He said its a 50 dollar part and he could did it and a full diagnostic for 1 hour of shop time. So it would cost me 127 plus tax.. Hopefully with this forum I can do it myself. I have seen pics of the part, but where is the vent valve solenoid?
    Mar 2011
    speedwell tn,
    11,884
    Re: EVAP Error Code
    before you throw any money in this i do suggest you check the evap hoses to make sure that none are cracked or damaged if you find none then you can worry about the vent valve solenoid which i will look into on it's location if i can find it man i do miss the good old day when cars didn't have everything tied into a computer.
  16. #14
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
    Re: EVAP Error Code
    look on my previous thread about this it talks about the location of the solenoid...I had to order a new bracket with the vent valve solenoid. The valve was $50 and the bracket was like $150...and guess what...it came back on about 3 mos later...but good luck
  17. #15
    djais1801's Avatar
    Feb 2011
    NJ
    47
    246
  18. Remove Advertisements
