getting ready to install a second radio
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, getting ready to install a second radio in Cadillac Escalade Forums; like the title says i am going to install a second radio and i was wondering how long is the ...
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    like the title says i am going to install a second radio and i was wondering how long is the wiring harness for the cd changer between it and the radio
    Old Guy is offline Cadillac Owners Fanatic
    Automobile(s): 03 Tahoe... sold 05 ESV
    Aug 2010
    Mansfield, Texas
    48
    153
    Re: getting ready to install a second radio
    I had to pickup the 12v switched lead from behind the radio, so I just ran a ground, batt along with it. Its important to run the same ground as the radio to reduce any possibility of engine whine or accessory noise.
    Mar 2011
    speedwell tn,
    11,884
    i know which wire is which on the radio can i use the power wire from the radio then feed it to my other radio
    Aug 2010
    Mansfield, Texas
    48
    153
    I am sure you can especially if your setting it up like I did, with the radio only using the line-outs and not the speaker outputs, it will pull far less current that way, which should keep it within the amp rating of the oem setup.
    Mar 2011
    speedwell tn,
    11,884
    i got hooked up and it works great just need to know how did you mount your radio in the cd changer location i thought of using the brackets off of the cd changer since i will be relocating it as soon as i have time to extend the wiring to be under my left second row seat i know i won't using it much but i want to keep it in the truck in case i don't have my cable for my iphone so i won't be without my music
    Aug 2010
    Mansfield, Texas
    48
    153
    I used the metal cage that the radio slides into that it came with... but mounted it behind the panel instead of in front of it.
    Mar 2011
    speedwell tn,
    11,884
    did you use the mount tabs from the stock cd changer or not but i have the metal cage that my jvc came with
    Mar 2011
    speedwell tn,
    11,884
    i got it in and it looks great with the dash plus i also relocated my cd changer to under my left second row seat all i needed was a ethernet cable and a lot of time it took two days form start to finish but i am done and it turned out great
    Mar 2011
    speedwell tn,
    11,884
    i can take pics if you want to see just pm me and i will take some
    Mar 2011
    speedwell tn,
    11,884
    and the odd thing to it is when i had the stock radio out and unplugged to run the wires for the jvc the chimes still worked weird as can be any clues on that
  13. Remove Advertisements
