Results 1 to 3 of 3
Thread: 2003 Escalade Air Ride; No power to compressor. New Shocks and compressor
    Enfuego74 is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Jun 2011
    43
    4
    I replaced my rear shocks and compressor(second time) on my 2003 escalade. The first replacement compressor worked fine, but I had leaky shocks. I unhooked the compressor until I had more time to fix everything. The first replacement compressor did not work when I plugged everything in to finish the repairs. I had the compressor tested and it was bad. New compressor will not come on at all. No power to the compressor when I cheked it with a test light. Fuses are all good. I have read that I may have a bad relay. Any comments on where it is? Suggestions? I am getting a Service Stability on Message Center. Codes from the scanner are CO660(Level Control Exhaust Valve Circuit Malfunction) and CO711(Level control Air Pressure Sensor Circuit Malfunction). Any help would be great!!
    sk7's Avatar
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    Re: 2003 Escalade Air Ride; No power to compressor. New Shocks and compressor
    Read the thread just below yours for all the answers to your ALC questions! Good luck! (one million dollar question thread)
    Jun 2011
    43
    4
    Thanks. I will be starting with the relay. Keeping my fingers crossed.
  • You may not post replies
