2003 escalade ext Passenger air hot..New actuator
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2003 escalade ext Passenger air hot..New actuator in Cadillac Escalade Forums; Hello,working on a 2003 Escalade ext..The passenger side ac would only blow hot,on auto or manual..Driver side responded to temp ...
    trvcampbe is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2010
    45
    5
    Angry2003 escalade ext Passenger air hot..New actuator
    Hello,working on a 2003 Escalade ext..The passenger side ac would only blow hot,on auto or manual..Driver side responded to temp knob when turned..Removed dash and replaced actuator for passenger side...Still hot only...Any ideas..Does this system have a self diagnostic for the ac?...I operated the door by hand while i was in there and it has full range of motion..Any ideas on how to check the module..I also did the pull the fuses after the repair--total of three for 10 minutes and then replaced and crunk it up ..Allowed 5 minutes before i touched any controls..Still same thing..help
    Automobile(s): none
    Jan 2010
    45
    5
    Re: 2003 escalade ext Passenger air hot..New actuator
    10 views and no replies?..Somebody has got know this system...Does it have a self diagnostic? I am using a snop on solus Pro and dont see any options for the Climate control module..
