Adding 1 brand new tire with 3 older ones
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Adding 1 brand new tire with 3 older ones in Cadillac Escalade Forums; Well I got a 3/8 in. bolt through the center of my drivers rear tire. I bought 4 new yokohama ...
    bizzob223 is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade ESV Platinum
    Feb 2010
    Michigan
    75
    Well I got a 3/8 in. bolt through the center of my drivers rear tire. I bought 4 new yokohama 20's back in november and they have between 8-9/32 tread left. They started with 11/32 tread. I have always heard that you should replace both tires on the same axle especially with AWD as it can cause trouble due to the different tire diameter. Would 2-3/32 cause an issue if I put 1 new tire on the truck (06 ESV Platinum)?
    Bob
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    Re: Adding 1 brand new tire with 3 older ones
    absolutely no problem. if it bothers you, check ebay for the same used tire around 8/32. But 8-9/32 is still plenty of meat so you should be fine.
