OBDII scanner problem, can not read codes
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, OBDII scanner problem, can not read codes in Cadillac Escalade Forums; Hey guys, I've been trying to read the error code that my escalade is giving me, but the scanners I'm ...
    ESV_Platinum is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade ESV Platinum
    Mar 2011
    24
    Hey guys,
    I've been trying to read the error code that my escalade is giving me, but the scanners I'm trying at autozone and other auto parts stores are not getting any readings. It does not appear that it is getting any power, I checked the connections that go to the port and they all seem to be in tact. No ripped or torn wires.
    I'm sorry if I wasn't able to do a proper forum search, I'm on the road traveling and want to see what's wrong and if I need an emergency shop visit while away.
    Thanks guys,
    Al
    Sent from my iPhone using Tapatalk
    Jlgarza66 is offline Cadillac Owners Member
    Automobile(s): 2003 escalade AWD 6.0 L
    Mar 2011
    51
    9
    I had the same problem. I found the fuse for the cig. lighter (found a penney had fallen into it) was blown. Apparently the diagnostic connecter get it power from the same circuit.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: OBDII scanner problem, can not read codes
    Under hood fuse block, replace the cigar lighter fuse.
    Mar 2011
    24
    Fixed it guys! Thanks so much for the responses they were dead on!
  7. Remove Advertisements
