2005 Escalade (LED) DRL & Turn Signal Trouble
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2005 Escalade (LED) DRL & Turn Signal Trouble in Cadillac Escalade Forums; I have a 2005 escalade I recently bought 3157 led lights for my DRL's and front turn signals. When i ...
    Bob Halas's Avatar
    Bob Halas is offline Cadillac Owners Member
    Automobile(s): 05 Escalade on Davin Black Onyx
    May 2011
    33
    Angry2005 Escalade (LED) DRL & Turn Signal Trouble
    I have a 2005 escalade I recently bought 3157 led lights for my DRL's and front turn signals. When i installed them the DRL's didnt come on at all and when i went to use turn signals both the dash turn signal lights lit along with my mirror and taillights, they just lit sold and stayed on but the front leds didnt light at all???
    (I know the drls are 4114 bulbs but i already had 3157 blue miniature bulbs in the sockets and they worked fine)
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: 2005 Escalade (LED) DRL & Turn Signal Trouble
    the led's should work fine something ain't right cause i run led's in my drl's right now check the sockets the blinkers is using the non heavy duty flasher mine does the rapid flash with led bulbs and i use the same number but mine is white led's in my drl's get a heavy duty flasher it might fix the issue
    Bob Halas's Avatar
    May 2011
    33
    Is the heavy duty flasher something I can get at autozone or another parts store or is it a special order part? And I still don't know what to do about Drl's..
    Mar 2011
    speedwell tn,
    11,884
    yes but i haven't asked but they do have flashers for the escalade
    niftymonte is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    May 2011
    29
    41
    may be a simple question, but did you try flipping the bulb around? LEDs have a polarity so they only work one way in the socket. When I put mine in I had to flip them both.
    Mar 2011
    speedwell tn,
    11,884
    no i didn't think about it i may try it next time i have the hood up which is rare for me since i don't have much trouble from my truck i may just go ahead and try it tomorrow to see if it works thanks
    godsdiablo's Avatar
    godsdiablo is online now Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac Escalade
    May 2008
    New York
    1,177
    If not I would try using 4114 bulbs instead
    Mar 2011
    speedwell tn,
    11,884
    they don't make 4114 bulbs for the drls and it is the front blinkers that give issues with but i will try flipping them before i put them in the blinker sockets like niftymonte posted i have 3157 led's with no problem in my drl's
    Mar 2011
    speedwell tn,
    11,884
    tried fliping them and i still got the ripad flash so i guess i need the heavy duty flasher
    CEPMAN is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Escalade ESV
    Jul 2009
    NC, USA
    36
    360
    For LED DRL's if they don't light up, you need to flip them and make sure they're seated really well. I have some in mine, and when I installed them, I had the same issue. I actually turned them around and got them to work, but then turned them back the wrong way because I like the look better without them lit up.
    As for the hyper flash - the LED's don't have the electrical load that regular bulbs have. Therefore the truck thinks that the bulb is out (hence hyper flash) The fix I did (because I have LED tails) was to get some $3 trailer tail lights from Walmart and wire them into the signal wiring, and mount them under the truck. Problem slved, for $3.
    Mar 2011
    speedwell tn,
    11,884
    the catch to that is i tow a trailer sometimes with my lade so i guess i need some other way
    pmartell12's Avatar
    pmartell12 is offline Cadillac Owners Fanatic
    Automobile(s): 2015.5 black premium, sold my black 2003 ESV
    Jul 2010
    London, Ontario, Canada, 11450
    40
    141
    @ the cadillac man - i believe cepman was trying to say that he took a set of cheap trailer lights and spliced them into the body's signal wiring (taillights)- essentially leaving the trailer wiring untouched
    Mar 2011
    speedwell tn,
    11,884
    but the thing to is i have issue with front blinkers but i do have a set of trailer lights i might try it and see what happens unless i can get a hold of a set of load equalizers for the front
  16. Remove Advertisements
