2002 Escalade Fuel Guage problem - need help
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2002 Escalade Fuel Guage problem - need help in Cadillac Escalade Forums; My wife and I took a quick trip from Houston to Dallas this weekend and half way to Dallas (100 ...
    TColeman is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Escalade AWD
    Oct 2010
    19
    My wife and I took a quick trip from Houston to Dallas this weekend and half way to Dallas (100 miles) my 2002 Escalade fuel guage went to empty... I just filled up and even put Gumout fuel injector cleaner in before fillup.
    During our commute, every now and then it would show full tank, but for about 75% of the drive it read empty. What's happening? Is this common? What do I do to fix?
    The truck drove fine, it just showed I had no gas - what gives?
    Thanks for the help guys....
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: 2002 Escalade Fuel Guage problem - need help
    i think there is a sensor in the tank that might be bad only way of replacing it is by droping the tank and checking the wiring for the fuel sender system that goes to the sensor
    Oct 2010
    19
    Just wanted to update incase anyone has ever had this problem (tahoe, escalade etc...). It needed a new fuel sending unit, so I took it to my local mechanic and had him drop the tank. He works for $80/hour and I purchased the ACDelco fuel pump assembly. I was told not to go aftermarket (Autozone etc), so I bought this off of ebay brand new for around $265. AdvancedAuto was asking around $400+ just for the part.
    Anyway, he replaced the entire fuel pump assembly (includes fuel sending unit) and it works like a charm. Total out the door bill was $265 parts and $300 labor. You can do this yourself but I'm not experienced enough to do the job so I didn't mind paying someone.
    dumbyell is offline Cadillac Owners Member
    Automobile(s): escalade
    Apr 2011
    1
    Question; what caused your fuel sending unit to go out? I began having that same problem along with a few other wiring type issues over a year ago. Just recently, the problem has gotten TERRIBLE! We've had the fuel filter changed, the fuel pump tested, etc but yet my Escalade continues to act as if it's running out of gas! We've tried it all, EXCEPT ANY WIRING TESTING/CORRECTING. I'll put in $30 of gasoline and end up "out-of-gas" in ten miles and the ONLY thing that gets it going again is more fuel!!! Could it possibly be the wiring and once I add more fuel, the wiring unit is thinking its ok again??? HELP!!! GAS IS COSTING ME $100/day LITERALLY AT LEAST AND I ONLY DRIVE 50 MILES TOPS A DAY
    mitch2264's Avatar
    mitch2264 is offline Cadillac Owners Member
    Automobile(s): Cadillac Escalade Platinum
    Dec 2007
    ATL
    79
    I remeber reading something several years ago about sulfur in gasoline being a contributing cause. I Googled "Sulfer in gasoline GM" and found this that I cut & pasted below. Not sure if this will help or not, but interesting for sure:
    "GM has just issued a TSB
    on this problem that applies to ALL GM vehicles and
    blames the high incidence of sending unit failures
    on high levels of sulfur in gasoline. The sulfur
    corrodes the sliding resistor mechanism and
    produces erratic and inaccurate gauge readings. To
    address this problem, GM has released a FUEL
    TANK ADDITIVE.
    According to GM TSB #06-00-89-07BB, you should
    purchase a bottle of GM Fuel System Treatment
    Plus (part #88861011 for GM brand, 88861013 for
    AC Delco brand, and 88861012 in Canada) and add
    it to your tank at every oil change. The additive
    cleans the sulfur corrosion from the sending unit
    and prevents new corrosion by laying down a
    protective film. The additive also removes engine
    deposits."
    Good luck!
    Mitch
    osure is offline Cadillac Owners Member
    Automobile(s): 2005 escalade
    Apr 2012
    mpls,mn
    46
    89
    Quote Originally Posted by dumbyell View Post
    sounds like a motor issue not a fuel issue. what are you getting for mileage? First thing I would look at is fuel presuure regulator(if you are really getting that bad of gas mileage.)
  9. Remove Advertisements
