Results 1 to 9 of 9
Thread: Need advice from GM mechanic regarding Tech II RE: Gauge Cluster
    CaddyEscalade is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    May 2010
    231
    I am looking to purchase a new gauge cluster for my Escalade. I am looking for info from a GM tech regarding the mileage. Can a mechanic program the correct mileage for my vehicle on the new cluster with a GM Tech 2? I have not been able to find any information on this.
    Thanks in advance!
    Sep 2007
    Wilmington, NC
    13,969
    Re: Need advice from GM mechanic regarding Tech II RE: Gauge Cluster
    A Tech2 will HAVE to be used to program the mileage (as far as I know).
    May 2010
    231
    Thanks, just would like to know for sure before I buy a cluster. If it is too much of a huge deal then i wont bother. I have people can be real touchy when discussing mileage adjustment, and I know someone with access to a Tech 2.
  5. #4
    Sep 2007
    Wilmington, NC
    13,969
    where are you buying a cluster?
    if it's a used cluster then you might have a problem, but if you're buying a new cluster i have to as where are you buying from?
    if you are buying from one of the ESCs (electronic service centers) like specmo or united radio then it's a possibility that they will program the mileage for you
    they will let you know if they can or can't
    i wouldn't get a cluster from anywhere but the ESCs
  6. #5
    smelly$cat is offline Cadillac Owners Fanatic
    Automobile(s): 2003 ESV
    Jul 2009
    39
    325
    I'm curious WHY you are buying a new cluster. They can usually be repaired for CHEAP via various ebay services. Just fixed my friends suburban for 50.00 plus shipping to the tech. His speedo was way off. They replaced all the stepper motors and bulbs for this price and shipped it back to him.
  7. #6
    Sep 2007
    Wilmington, NC
    13,969
    Quote Originally Posted by smelly$cat View Post
    if this is your problem then check with your local dealers first and ask about the 'special coverage' for the instrument clusters... they were covering up to 70,000 or 80,000 miles (i think) and if you have a good relationship with your dealer they can 'goodwill' it for you if they want no matter what your mileage
    and the ESCs will do pre-exchanges for you. they will send you a cluster and hold your credit card info in case you don't send back your core - usually costs less than $200 (i think)
    or you can send it in to them and they'll call you w/ a repair cost ($35 or so for diagnostic in case you decline the repair)
  8. #7
    May 2010
    231
    I found a wrecked 06 for parts with a nicer looking gauge cluster. I believe the mileage is actually higher than on my truck, so I want to make sure if I buy it that I can get it adjust to match my mileage. I just want to know if it can be done first before I go and talk to my dealer, as I am not sure what they will say about the process. I want to see from someone who has done this, to make sure I am not told something different.
    Thanks for the help, hopefully there is a Caddy tech who can help.
  9. #8
    May 2010
    231
    There is also a NAV unit available, so maybe I can kill 2 birds from the delaer and have them program the milage and change the VIn on the Nav unit. As I know this can be done with a Tech 2 unit.
  10. #9
    Sep 2007
    Wilmington, NC
    13,969
    dealers typically don't like to do this kind of stuff... but good luck ... i would think that' it's possible - just getting it done is going to be the hard part
    definitely check out the threads on this site regarding the nav upgrade mod
  • You may not post replies
