Results 1 to 5 of 5
Thread: Check Engine Light - Misfire in Cylinder 5?!?!
    AndrewAdams211's Avatar
    AndrewAdams211 is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade
    Apr 2011
    New Jersey
    31
    14
    Ok, so I've got a check engine light on. I got it checked out at Advance Auto, they said it's a "Misfire in Cylinder 5".
    Ok...no problem....I'm at 104k on my Escalade...guess it's about time for a tune up. Can ANYONE give me SPECIFIC instructions on HOW to do this? Pictures would be great. It's a 04 Escalade 6.0...I'm just replacing the Sparks & Wires. What kind should I use???? Anything special????? Also, anything else I should look out for when doing this????? Any "heads up" info???
    Sorry for all the questions in 1 post...
    Supercaddyman93 is offline Cadillac Owners Member
    Automobile(s): 2004 escalade
    Mar 2011
    23
    30
    Re: Check Engine Light - Misfire in Cylinder 5?!?!
    Go back to Advance and have them look you up spark plugs and wires.... i have the exact same car and i put bosch platinum iridium spark plugs in mine and it runs great... the only problem is getting the spark plugs out. anyone that did it themselves like me knows that this is probably the most difficult thing to do on the escalade because the spark plugs and stuck in there and half of them are so far back that you can hardly reach them.... but good luck, hopefully yours will be a lot easier than mine was
    Apr 2011
    New Jersey
    31
    14
    Ok...so yesterday I replaced ALL 8 spark plugs and wires. Was A HELL OF job but got it done. So I drive to Advance for them to clear the code...they clear it and I drive home PROUD of my work.
    Pull off to go to the grocery store and WTF...the code is back on. I'm have OCD with this truck...so forget the groceries...went BACK to Advance, SAME THING...Misfire in Cylinder 5!! I'm GOING CRAZY!!!
    Now...Advance tells me to try the Coils...WHICH coil is cylinder 5????? I'll do some switching and see if the problem follows the coil.
    HELP PLEEEEEEEEEEEASE!!!!!
  5. #4
    Mar 2011
    23
    30
    i have no idea.... sometimes the wires are marked.... probly not on our gm cars tho
  6. #5
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    you should get together with 04CADESC a few threads up. he has misfire also. thinks he has a bad injector. he put on a new coil for a bad cylinder but still has miss. i think injectors are pretty stout. don't hear about them failing. but it could happen.
  • You may not post replies
