Stealership never put in any tranny fluid!!!!
Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Stealership never put in any tranny fluid!!!! in Cadillac Escalade Forums; So to get to the point the transmission can shift from 1st to 2nd THATS IT! It wont shift into ...
    xxe92xx is offline Cadillac Owners Member
    Automobile(s): '10 Premium EXT
    Dec 2009
    Milwaukee, WI
    34
    67
    So to get to the point the transmission can shift from 1st to 2nd THATS IT! It wont shift into third. I took it to a independent shop and the guy drove it and noticed the obvious problem so he looked under the hood and checked the transmission fluid dip stick. NO FLUID! So I took it to the cadillac dealership that changed all my fluids a month ago and they noticed the same stuff.
    The tech at the caddy dealership added 1 quart of oil to the transmission. I was confused because if the dip stick says theres no fluid in the transmission than what the hell is 1 quart of fluid going to do??? Theres only 2 ways that could have caused this problem 1) There was a massive leak and I dumped out 12 quarts of fluid!!! or 2) they never put in any fluid after they flushed the tranny
    Thoughts? Should I get a brand new transmission for this bullshit?
    CEPMAN is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Escalade ESV
    Jul 2009
    NC, USA
    36
    360
    Re: Stealership never put in any tranny fluid!!!!
    If you could either 1. Prove they did it or 2. Get them to admit to it, then yes. But even if they were to admit to it or believe you, they'd first just fill it up and test it out. If everything worked, there's no way they'd suck up that much money just to make you feel good.
    Dec 2009
    Milwaukee, WI
    34
    67
    the tech said something along the lines of this: we checked the fluid and as you said the dipstick showed no fluid and there is also a sign of a minor leak....we added 1 quart of fluid, test drove it and the problem was still there (wouldnt shift into 3rd gear)
    what i dont understand is if the tranny needs 12 quarts to perform correctly, why just add 1 quart? according to the dipstick there is no fluid in the tranny so why add only 1 quart? so if the dipstick showed no fluid then that means theres no fluid in the tranny..correct? and if there is a minor/small leak how long would it take to dump out 12 quarts of fluid?? the service was done 2/8/11 and i brought it on on 3/29/11
    we have the invoice/recepit of the work that was done and it states on there that driveline service was performed...differentials, transmission, transfer case
    theres no way they cant admit they caused this, because like i said there are only 2 possibilites and 1 of those possibilities is more believable than the other
    what i think happened is the tech flushed the tranny, emptied the the fluid, put everything back together and forgot to add the tranny fluid
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Well, I'm not sure if this is about your 2010 truck because you are in the wrong forum (this is for 1999-2006 trucks, we have a separate forum for 2007-2012), but with a purchase date THAT recent and proof of prior service performed that recently, there is really no way they can get out of this. Everything is stacked against them because not only did they supposedly perform the inspections and services that should have caught this, or may have CAUSED it, but you have factory warranty on top of that.
    Sometimes these situations can be difficult to rectify since they are going to look out for their bottom line, but I would be very leery of letting them just fill it back up and sending you on your merry way. If it DOES fail later, it will be more difficult to prove that your abuse didn't cause the damage. These 6L80 6 speeds have enough problems without this kind of ridiculous mix-up.
    Dec 2009
    Milwaukee, WI
    34
    67
    its a 2004 AWD with 80,000 miles
    can anyone tell me how many quartz the transmission dip stick reads?
    the dealership called today and said the transmission will need to be replaced, they dont know "what" caused it....what im wondering is if the fluid was low enough to cause this because before i had my trucks fluids changed (tranny, transfer, differential) it was running fine, i mean the tranny "slipped" once a blue moon but it was fine no problems
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    i would assume that when there's just a bit of fluid on the dipstick there's still a bunch of fluid in there (no clue though as to how much)
    Dec 2009
    Milwaukee, WI
    34
    67
    there was some on the very end of it and it had a burning smell
    Sep 2007
    Wilmington, NC
    13,986
    yeah obviously it's not supposed to be operated that low and if they're saying it needs to be replaced and you just had it serviced by them you probably have a leg to stand on
    but
    how you approach the situation (and their service manager) will probably have a lot to do with how the situation gets resolved
    firm yet polite is how i describe the best approach to these types of situations
    Dec 2009
    Milwaukee, WI
    34
    67
    but
    ok so judging by your response, i was right all along?....if there is no fluid on the dip stick (or barely any on the end of it) there is little to no fluid in the transmission? so far no one has answered this question, can anyone explain this to me?
    because the service guy at the dealership said the dipstick only reads 1 quart, another guy from a different shop said 2 and another guy from that same shop said 7 quarts...?
    but even if it reads 1 quart low there is no way to find out how much is actually in the transmission and judging by the damage to the transmission it is the result of low fluid, correct? (1st and 2nd work with some slippage, but it doesnt shift into 3rd at all)
    Sep 2007
    Wilmington, NC
    13,986
    i can't say from experience... i'll ask around tomorrow
    Dec 2009
    Milwaukee, WI
    34
    67
    bump
    Sep 2007
    Wilmington, NC
    13,986
    ooops... sorry i forgot to ask around... bump again tomorrow during work hours if i forget again
    Dec 2009
    Milwaukee, WI
    34
    67
    Update:
    So yesterday I was waiting for a call from the dealership...never got it so I called right at closing time (5:00pm). The original service adviser I talked to was unavailable??? so I talked to a different service advisor and he told me they werent going to even bother opening up the tranny to see what wrong because its obvious it needs to be replaced and he quoted me for a REMAF tranny for 2795..he also said it had nothing to do with less fluid???
    SO I talked to the SERVICE MANAGER today and he said he never authorized anything yet. He didnt have any knowlege of what the 2nd service advisor told me...!!!! WTF!!! He said drop the car off so they could find out what wrong....
    Thoughts?
  16. #14
    Dec 2009
    Milwaukee, WI
    34
    67
    bump
  17. #15
    Old Guy is offline Cadillac Owners Fanatic
    Automobile(s): 03 Tahoe... sold 05 ESV
    Aug 2010
    Mansfield, Texas
    48
    153
    This is a very common thing in fact, ppl get a flush, tranny doesnt work afterwards. The flush is moving metal and goop into/through places in the tranny it wasnt before since it was stuck somewhere all nice and safe. Some chunk of metal shavings is/was now loose and floating around ready to wreck havoc because of the flush and in your case it sounds like it found a home in some little passageway or orifice in the valve body or worse. If the tranny was slipping before the flush then you took a real gamble by having it flushed thinking that would fix it vs. toasting it.
    Even just changing the fluid on a worn tranny has been known to render one useless. I think most people know this, I am sure the dealership knows this, and chances are the advisor knows it too... that changing the fluid or flushing a used tranny can also negatively affect future tranny performance, just as you may be experiencing now. Good luck on getting the dealership to cover anything at all, I would consider yourself extremely lucky if you can manage to squeeze even half out of them towards a rebuild/or whatever.
  18. Remove Advertisements
