Rear air shocks won't deflate
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear air shocks won't deflate in Cadillac Escalade Forums; I recently replaced my rear shocks with Monroe 40034's, replacement was easy thanks directions found on this forum. The shocks ...
    pugslayer is offline Cadillac Owners Member
    Automobile(s): escalade
    Feb 2009
    upstate New York
    51
    6
    I recently replaced my rear shocks with Monroe 40034's, replacement was easy thanks directions found on this forum. The shocks seem to inflate fine, but they don't deflate. I put my trailer on and the shocks inflated to level the vehicle, the problem is when I take the trailer off the rear stays jacked up. The only way I have found to bring the vehicle back down is to remove the air supply to the shocks. Anyone out there have any suggestions???? Is it possible my compressor is bad, does it have anything to do with deflating the shocks?
    Feb 2009
    upstate New York
    51
    6
    Re: Rear air shocks won't deflate
    Anybody????
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    if you are getting a service ride control your compressor is the cause unless there is a sensor wire that you didn't hook up right or the sensor is bad this is why i don't like some replacement shocks luckly i haven't had to change mine but the compressor is needing to be replaced on mine
    Feb 2009
    upstate New York
    51
    6
    Thanks for the input, I spoke with the folks at arnott on Friday and explained the issue. They said the exhaust valve on the compressor was most likely the problem. New compressor and rebuild kit for the dryer 179.00 with free shipping. Thanks again for the input.
    Mar 2011
    speedwell tn,
    11,884
    that is the same thing that is wrong with mine could you make a step by step guide to make it easier for those of us that may need it like my self Please
    i just have to order a new compressor to put on mine cause mine won't do anything cause the exhaust valve solenoid is bad on mine
  8. Remove Advertisements
