Factory HID Install in 2002 Escalade
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By stock545i
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Factory HID Install in 2002 Escalade in Cadillac Escalade Forums; Hey guys - what am I missing here?? I had aftermarket headlights on my EXT, and I wanted to replace ...
    stock545i is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Jan 2011
    47
    8
    QuestionFactory HID Install in 2002 Escalade
    Hey guys - what am I missing here?? I had aftermarket headlights on my EXT, and I wanted to replace with OEM. I picked up a set of D1R's with the bulb and ballast setup. However when I took off the aftermarket headlight I see only one harness. This harness plugs directly into the headlight. So all I have been successful is to get all lights except my low beams to work. I cannot find the harness to plug into the ballast. If you have done this mod, where is the harness to plug into the ballast?
    Thanks in advance, and if I'm screwed either ways let me know.
    On another note, I've got an issue with the angel eyes with my projector aftermarkets. If I am unable to get the OEM HIDs to work, then any ideas on where I can get the angel eyes - I've got 2 burnt AE's.
    bstiffmanofsteel's Avatar
    bstiffmanofsteel is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Jul 2008
    Elmhurst, IL
    38
    1,042
    Re: Factory HID Install in 2002 Escalade
    I honestly can not remember anyone adding OEM headlights to a 2002. I personally went aftermarket, plug and play! The Angel eyes were all over ebay, just search Escalade headlight and sift through the results. I wish I could offer you more as to your install. Goodluck!
    Jan 2011
    47
    8
    It has been done apparently, and requires a wire tap.
    Can someone confirm that the pins H and J are the Low Beam Pinouts in the 10 pin connector that plugs into the headlight? If yes, looks like all I need to do is tap the 2 and get a female connector to plug into the ballast.
    Jan 2011
    47
    8
    Yes - It can be done!
    silent_mv likes this.
    Automobile(s): NONE
    Jul 2008
    Elmhurst, IL
    38
    1,042
    Nice, congratulations!
    Jan 2011
    47
    8
    Quote Originally Posted by bstiffmanofsteel View Post
    Thanks! Looks like I've got a set of projectors for sale now.
    silent_mv is offline Cadillac Owners Member
    May 2011
    Bay Area
    32
    Hi do you by any chance have pictures of the wiring you did to get the oem hids working? Any help will be appreciated.
    I just bought a set of oem hid headlights that i want to install in my truck. They come with the oem philips 3 pin ballasts.I do have the 3 pin plugs already as wellas a hid relay wiring harness with resistors. I dont want burn anything and want to keep it as factory as possible thanks
  10. Remove Advertisements
