Results 1 to 2 of 2
Thread: 02 Escalade - what headlight bulbs do i need ??
    theboss is offline Cadillac Owners Member
    Automobile(s): 'Lade
    Nov 2009
    5
    The Daytime running light is out (when the truck is running and in gear)...is it part #4114 ????
    And I think I have a low beam out (it was out, then on, then off again..weird)....it it a #9006 ???
    Just having trouble figuring out what i need to get before I take everything apart..and my wife has the truck so no manual handy..please help quick! These are the #'s Part Source (Canada) gave to me.
    Nov 2009
    5
    Re: 02 Escalade - what headlight bulbs do i need ??
    found an online manual pdf....this is what the manual says...do the other numbers works as well or just these..now i am confused.
    Replacement Bulbs *Lamp Bulb Number
    Low-Beam Headlamps 9005 or 9005LL (Long Life)
    High-Beam Headlamps 9005
    Daytime Running Lamps (DRL) 4157K (Preferred) or 3157KX
    Front Marker Lamp 194
    Front Parking and Turn Lamp 3157AK
    Taillamp and Stop Lamp 3157K
    Rear Marker Lamp 194
    Rear Turn Lamp 3157K
    Back-up Lamp 3157K
  • You may not post replies
