A possible quick and cheap solution to the Crappy,leaky,oil and tranny cooling lines? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, A possible quick and cheap solution to the Crappy,leaky,oil and tranny cooling lines? in Cadillac Escalade Forums; Does anyone have the part numbers for the transmission cooler lines that go from the transmission to the radiator? This ...
  1. #16
    carlmcad is offline Cadillac Owners Member
    Automobile(s): carl@partnershipresources.com
    Nov 2012
    6
    Re: A possible quick and cheap solution to the Crappy,leaky,oil and tranny cooling li
    Does anyone have the part numbers for the transmission cooler lines that go from the transmission to the radiator? This is what I have; ACDelco 15809053 for 1 line, don't have the second line part number.
  2. #17
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by carlmcad
    I think they are both the same but you can call a gm dealer to find out for sure
  3. #18
    thetobins's Avatar
    thetobins is offline Cadillac Owners Member
    Automobile(s): 07 escalade ext/ 04 srx awd
    Feb 2010
    45
    61
    Yep, this is just the ticket!
  5. #19
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,797
    Yeah those crimps seem to go bad often, I show 3 trans lines, trans to radiator 15267484, aux trans cooler to radiator 15809057, and aux trans cooler to trans 15813029, please double check all part number using your vin with the dealer
  6. #20
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wesyder
    Yep that's correct
    Mine is leaking at one of the crimps on the radiator which sucks
  7. #21
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    907
    I replaced my oil cooler lines with Doormans they started leaking just out of warranty. I used a pipe cutter and a pair of wire cutting pliers to separate the crimp from the rubber hose. I then used a screw type radiator clamp to replace the aluminium crimp that I cut off, no more leak and works like a charm. Just like the pictures posted in post #7.
  8. #22
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jnrsesv
    I may do that so I don't have to worry about as the top one is leaking on my 03(could be the radiator as its needing replacing)
  9. Remove Advertisements
