Rear passenger side lights not working!!!!!
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear passenger side lights not working!!!!! in Cadillac Escalade Forums; I have a 2003 escalade and the rear passenger side lights are not working.... the brake lights and reverse lights ...
    gabbys610 is offline Cadillac Owners Member
    Automobile(s): 2003 cadillac escalade
    Feb 2011
    38
    4
    I have a 2003 escalade and the rear passenger side lights are not working.... the brake lights and reverse lights work, just not the lights that stay on when lights are on.... I have read other post and found the plugs on the inside fender and cannot get the plug out to check for corrosion... i dont want to pry the plug off and risk breaking it.... please advise for ideas!!!!!
    sk7's Avatar
    sk7
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    Re: Rear passenger side lights not working!!!!!
    Ur almost there! There's a tab u need to push or pull before being able to slide the plug out. Clean the area carefully if you havent already done so, it will help to figure out out to remove the connector.
    Feb 2011
    38
    4
    yup i see it and iv tried it, usually when you see those tabs you push them in and im not getting anywhere... il try cleaning it again and try again!!! Thank you again for replying!!!!!
    nohopeboyz is offline Cadillac Owners Member
    Automobile(s): escalade
    Nov 2010
    15
    There should be a fuse for it aswell but I just had the same problem and the pin was busted off the module back there
    ecaroppo is offline Cadillac Owners Member
    Nov 2009
    Cambridge, Ontario, Canada
    44
    10
    Hey, I got the same problem happening with mine. The corrosion you're looking for, is that on the bulb socket or else ware?
    8mycsh's Avatar
    8mycsh is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade
    Jan 2007
    6
    Hi there I have 2004 escalade and I have the same problem with my right rear lights. You mention a post that you read, by chance could you direct me to it? When cleaning inside the fender connections do you mean remove the tail light assembly and clean the connections and bulbs? I checked the fuses and all seem ok. Thanks
  9. Remove Advertisements
