VCM (vehicle control module)
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, VCM (vehicle control module) in Cadillac Escalade Forums; Hi! I need to know where is the vcm located on the vehicle Cadillac Escalade 2000 Need to check for ...
    CadyEscalade is offline Cadillac Owners Member
    Jan 2011
    70
    3
    Hi!
    Need to check for bad grond or voltage....trowing code P1875
    Thanks!
    JG!
    JG! is offline Cadillac Owners Member
    Automobile(s): Escalade
    Nov 2009
    33
    50
    Re: VCM (vehicle control module)
    Under dash directly behind the steering column
    Jan 2011
    70
    3
    Thanks....will check that....and if you have something to help me with P1875 ???
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    The VCM was used only on a few years of production, it has lots of jobs but it's primary control function is powertrain management.
    It is located under the hood, I believe on the top of the left fender well near the brake master cylinder.
    Your P1875 is related to the 4WD control switch. It could be a bad switch, it has been a while since I messed with one of those.
    JG!
    Nov 2009
    33
    50
    my bad I was I was thinking BCM (body control module)
    Jan 2011
    70
    3
    Now I have another code P1631C..problem with security..need to wait 10 minutes..dont start.......
    Is That possible that my problem with the 4wd low(P1875) engaging by itself has something to do with the key or key cylinder...because the pcm,transfer case and key cylinder are interconnected.
    Thanks!
    P.S. replaced the switch box with a new (2wd,2HI,4wdh,4wdlow) and samething
  9. Remove Advertisements
