Open the hood, with a small screwdriver pry the heads up on the plastic fastners that hold the shroud down on top of the radiator and remove them, there is a bolt holding the grill in (1) I think it's 9mm, then release the tabs (2) on the top of the grill, just pull gently towards you, lift the grill out, then there are two rods that hold the headlight assy in (one is on the top, and one is on the side near radiator) remove those and the headlight will come out, to remove completly from the car you will need to unplug the wires that go to the lights, or put a towel over the bumper and the headlight assy will stay there, be careful they are costly. Once you do it the first time ot two the whole process takes less really 2-3 minutes.
It seems like a lot, once you do it once you will see it's just unbolting parts in a series of steps.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
