No rear temp control with new actuator - Page 2
Results 16 to 30 of 33
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, No rear temp control with new actuator in Cadillac Escalade Forums; Originally Posted by JG! Thanks guys for all the info. I found a guy on my local CL parting out ...
  1. #16
    CaddyEscalade is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    May 2010
    231
    Re: No rear temp control with new actuator
    Quote Originally Posted by JG! View Post
    Thanks guys for all the info. I found a guy on my local CL parting out his Cadi. So Im gonna grab the module maybe even the whole rear ac/heat unit from him and hopefully fix the problem.
    Let us know how it goes, I have the same problem but just manually set the actuator for heat and unpluged the wires for now, but it still bugs me that it doesnt work as it should.
  2. #17
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Quote Originally Posted by CaddyEscalade View Post
    How much?
    i'll need your VIN to make sure i look up the right one, but basically employee discount
  3. #18
    May 2010
    231
    Sent you a pm
  5. #19
    May 2010
    231
    03' Escalade
    Having problems with the rear temperature. I bought a new actuator, Dorman part#604-100 thinking this was the problem. After putting the new actuator in and no success. I tried my old actuator in the floor/ceiling location and the actuator works fine. So if its not the actuator and I have done the reset numerous times. What should I try next? Anybody else experience this problem?
    UPDATE: Ok, just decided to deal with this, and ordered a new actuator and the HVAC control module. First of all you did the same thing as me and purchased the Dorman part # 604-100, that is the WRONG PART. You need the Dorman 604-111 actuator. If this does not fix your issue then you need to replace the HVAC control module with the new part #15832319. This has fixed all my rear heating issues. Purchased the parts online from RockAuto for 1/2 the price of my local Caddy dealer.
    Syclone354 likes this.
  6. #20
    hutcholdschool is offline Cadillac Owners Member
    Automobile(s): escalade
    Feb 2012
    1
    CaddyEscalade thanks for the response you last posted I did the same as you and it fixed my problem as well. I will post my experience so it may help others in the future. My vehicle is a 04 Escalade regular model AWD 6.0. I too had no heat control from the rear. I had control of the vent to floor control in the rear. I took apart the panels and watched the actuators and when you would unplug the fuse called "ECC" on the driver side fuse area while the key is on and then plug the fuse back in both of the actuators would start to re-calibrate but then the actuator towards the rear or the heat door actuator would over travel past the line on the case and then would not work at all after that. The other actuator or vent control actuator would still work fine and control the vents but the heat control actuator was not working at all. I took the vehicle to the dealer and they said I needed both actuators replaced and that I needed a new upper case to prevent the air doors from over travel. Well I went and bought a 604-100 actuator and that did nothing at all not even a slight movement. So then I went and bought a 604-111 actuator and that would move but also over traveled past the line. At this point I came on here and saw your post about the control module part #15832319. I went and bought this module and put back in both of my original oem actuators and plugged in the new control module GM part #15832319 and tried again and this fixed it all. The dealer was totally wrong and did not diagnose the problem correctly. All I ended up needing was this new improved control module that stops over travel. I hope this helps others to quickly fix there rear HVAC unit. Thanks
  7. #21
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by hutcholdschool View Post
    i had the same problem and posted a how-to for anybody who have to replace the parts i just wish gm didn't use cheap modules for this kinda of stuff cause when mine did the overtravel it really screwed the module and ran my battery dead overnight so it costs me about 500 dollars for a battery,module and actuator when i only needed a new battery and module.
  8. #22
    yokatta is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Apr 2011
    10
    I am having the exact same problem with my '03. Just recently started blowing cold air in the rear. I tried and dorman 604-111 and it over rotated too. So I bought a control module GM part #15832319 off ebay (used) and it does the same thing, over rotates. Tried, as you all did, switching the floor/ceiling and the hot/cold and both work in the floor/ceiling position with both the old and new module. Maybe my used module is bad??? But it is part #15832319. Anyway, I am at a loss so I set it to heat and pulled the power and put it all back together before I pulled all my hair out!
  9. #23
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by yokatta
    Before throwing more money into it get the codes pulled Trust me on this as I have been in your shoes before and it costed me close to 500 by the time I was done The brain is the small black box just above the heater core hoses(this is what you need to replace)
    FYI the part number you got is for the old module which could have already had the over travel code go to a gm dealer and get a new one there is no programming needed to make it work but you may also need a new acutitior (not sure)
    Trust me I have been there before and know how you feel
  10. #24
    Apr 2011
    10
    I did take it to the dealer and paid $50 for him to check the codes and nothing came up. Even had him check the current and history and nothing. Which surprised me. I read on here somewhere that was the NEW part #. I know it was different than the existing one. If there is a new part # could someone share it with me please?
  11. #25
    John outlaw is offline Cadillac Owners Member
    Nov 2013
    9
    Does anybody have a picture of where this module is locatede, I have an 05 ESV that is doing the exact same thing?
  12. #26
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by John outlaw
    I did a thread in the sticky/FAQ section of the forum it has pics and has step by step instructions on how to remove the panel to access the system
  13. #27
    Nov 2013
    9
    Thanks
  14. #28
    Nov 2013
    9
    The panels you refer to are they in the passanger floor board if not I can't tell in the pics what you are removing to check or repalce the modules.
    Thanks
  15. #29
    Mar 2011
    speedwell tn,
    11,884
    The panels you refer to are they in the passanger floor board if not I can't tell in the pics what you are removing to check or repalce the modules. Thanks
    They are in the right rear of the truck if your referring to the rear hvac system
  16. #30
    Nov 2013
    9
    Thanks Cadillac Man
  17. Remove Advertisements
