HOW TO: Reset the "change oil" light on my 2002?!
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, HOW TO: Reset the "change oil" light on my 2002?! in Cadillac Escalade Forums; Can anyone please help?! I changed my oil and I need to reset the light. I did some research and ...
    LACbaby is offline Cadillac Owners Member
    Aug 2004
    70
    Can anyone please help?! I changed my oil and I need to reset the light. I did some research and I was able to find/do the following;
    - Hold down the oil life button. Well, I DON"T HAVE AN OIL LIFE READER(no percentage of life reader etc....) which means I don't have that option.
    - Turn key to ON and press the gas pedal 3 times. Well, I did that and now my "change oil" light flashes 5 times. What did I do or what does that mean?
    Any help would be very appreciated! Thank you.
    sk7's Avatar
    sk7
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    Re: HOW TO: Reset the "change oil" light on my 2002?!
    The oil life button is part of the 03+ generation dashboard. I forget if its 3 times or 5 times but always had no problem using the gas pedal at wot! The change oil warning starts blinking when the reset is sucessful, then key off and back on and its gone. It has to be done quickly as soon as ignition is on.
    Aug 2004
    70
    Quote Originally Posted by sk7 View Post
    Thanks for the reply. Makes sense why I don't have oil life meter...
    Now, regarding the oil light and pedal, it is 3 times with in 5 seconds. I did that and it did blink after I did it but now EVERY TIME I turn on the truck, the change oil light flashes at me 5 times. I don't know what that means.
    gmercedesbenz's Avatar
    gmercedesbenz is offline Cadillac Owners Fanatic
    Jun 2010
    Washington D.C.
    169
    Press down on the gas pedal all the way three times with the truck OFF. Then turn the truck on, light should then not come on. If it doesn't work the first time, attempt again. I have the owners manual that I can post a scanned copy of where it says this if you need it.
    Aug 2004
    70
    Quote Originally Posted by gmercedesbenz View Post
    Thanks for the help. I also have the manual and did exactly what it told me BUT if you read further, it also states if it doesn't go off, take it to a technician. I ended buying an OBDII scanner at Harbor Freight today and cleared it with no problem
    Thanks for the help everyone!
  8. Remove Advertisements
