Need Help!! 2002 Escalade!!!
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Need Help!! 2002 Escalade!!! in Cadillac Escalade Forums; Just bought 2002 Escalade 2 days ago and everything worked great. I accidently left the interior lights on last night ...
    CTSLack941 is offline Cadillac Owners Fanatic
    Automobile(s): Green Money 2002 Escalade
    Jun 2010
    Florida
    40
    127
    Just bought 2002 Escalade 2 days ago and everything worked great. I accidently left the interior lights on last night and of course the next day the battery was dead. Charged it and everything seemed fine. Anyways, I noticed today now only my heat and ac will only blow through my defrost vents! Im not sure if the battery dying had anything to do it with it or if something broke, I did hear a weird noise in the dash, but it went away. You turn the knob in all directions and it does nothing, it only blows through the defrost vents. Anyone have any ideas or ever have this problem? Thanks, Matt
    bstiffmanofsteel's Avatar
    bstiffmanofsteel is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Jul 2008
    Elmhurst, IL
    38
    1,042
    Re: Need Help!! 2002 Escalade!!!
    Try disconnecting the negative terminal and leaving it off for a few minutes. See if that resets your system.
    mosimann is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade EXT
    Aug 2010
    41
    64
    I had a bad connection on the battery terminals of my service van and had two problems. Low beams were dimmer and the fan was blowing much weaker. Like speed 4 blowing like 3. Charged the battery and drove a couple hours to make sure it was back 100% charged again. Problems solved.
    gmercedesbenz's Avatar
    gmercedesbenz is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Escalade
    Jun 2010
    Washington D.C.
    169
    Sounds like the auto climate got out of sync when you had to recharge your battery. I would try the "unplug and plug it back in" fix, just disconnect the battery for 10-15 minutes, and reconnect. This will reset everything in the truck and hopefully fix your problem. Just out of curiosity, which interior lights did you leave on? I know that if you leave the reading lights on, the truck will automatically shut them off after 20 minutes to avoid running down the battery.
    Jun 2010
    Florida
    40
    127
    I left the interior dome lights on.. I accidently pushed the rolling switch all the way up, so the dome lights would stay on all the time. I tried unplugging the battery and reconnecting, but im not sure how long I left it unplugged? Maybe 10 mins I would guess. I tried pulling certain fuses and then popping back in, still no luck... Any idea's???
  8. Remove Advertisements
