Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: Need Part Number 2005 Escalade Touch Screen Nav Radio
11-12-04, 12:24 AM
| | Cadillac Owners Member | | | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio Quote: |
Originally Posted by allwest Hi CadX6 - No this unit does not play DVD,s not in park, not even in my imagination. Sure wish it would. It does not let you put in destinations unless you are basically stopped. It does not have an aux input for a rear camera. That would have been nice. | Check out PAC: http://www.pac-audio.com/products/video.htm
They have an adapter that will give you AUX video input into your factory NAV System.
Klaus |
12-09-04, 03:32 AM
| | Cadillac Owners Fanatic Cadillac(s): 2003 Cadillac Escalade | | Join Date: Mar 2003 Location: S.F / www.Luxury4Play.com Age: 32 | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio Quote: |
Originally Posted by allwest Installed the Touch-Screen Navigation Head unit GM part number 10377531, GPS Antenna GM part number 15135178, DVD Mapdisk version 3 GM part number 10390370. Had the dealer reset the theftlock and it works like a dream. | allwest, i was wondering if you have a 'Y91' code on that sticker label inside your glove box. if you do have one, im gonna make sure i get a navi with the same exacy part # as the one you got. thanks |
12-18-04, 01:34 PM
|  | Cadillac Owners Member Cadillac(s): BLK 07 ON 26's | | Join Date: Dec 2004 Location: Lancaster, CA | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio Quote: |
Originally Posted by allwest Hi CadX6 - No this unit does not play DVD,s not in park, not even in my imagination. Sure wish it would. It does not let you put in destinations unless you are basically stopped. It does not have an aux input for a rear camera. That would have been nice. | Got this from another thread, can you try it tell us if it works with this model.. OK Fellow Caddiers, over in the SRX Forum, we've got the "crack"--IF your NAV system is a Denso like ours is. (yours might not be)
Push & hold the musical note for at least 3 seconds to get to the "code" screen. Enter 1791 and hit ENTER. Now, if you remove your NAV DVD and insert a DVD movie, it'll play all the way to TIMBUCKTOO! Remember, though, this is ILLEGAL!
Now we're working on a way to use all the route menu while moving. By the way, the "cut-out" is NOT wires, it's part of the speed sensor system.
Come on over to our forum to sign up for the # volunteering! We need all the help we can get.
thanks |
12-18-04, 04:58 PM
| | Cadillac Owners Fanatic Cadillac(s): Escalade EXT | | | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio Does this code need to be entered everytime? Or once and done? |
12-18-04, 06:06 PM
|  | Super Moderator Cadillac(s): 2002 Aspen White Escalade | | Join Date: Feb 2004 Location: Bayside, NYC Age: 24 | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio That code is only for the SRX navigation units. The ones in the Escalade are made by a different company. For the Escalade NAVto play DVDs it needs to be physically modded.
__________________ ~Steve |
12-20-04, 09:42 PM
|  | Cadillac Owners Member | | Join Date: Dec 2004 Location: MA Age: 34 | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio Here 1 on Ebay #7942666928 buy it now 1300.00 |
12-23-04, 04:03 PM
| | Cadillac Owners Member | | | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio so... there's no way we can get our touch screen nav to play DVDs huh?  |
12-27-04, 05:53 PM
|  | Cadillac Owners Member Cadillac(s): BLK 07 ON 26's | | Join Date: Dec 2004 Location: Lancaster, CA | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio i think it is, read these forums and you will see.. |
01-04-05, 11:06 PM
Originally Posted by allwest capjand1
At this point the Radio which was purchased on E-bay for $1050 and came with Version 3 map disc, GPS Antenna about $50 from GMpartsdirect.com. Manual from GM for about $12. And a trip to the dealer for the reset $32, and I had the reset instructions for the Tech-2 already printed for the dealer. Now I installed the GPS antenna and radio. To install the GPS antenna, I had to remove the top cover of the dash in addition to the instrument panel bezel. This whole job consumed about 1 and 1/2 hours because I had not done it before.
A couple of hidden costs were inherent in the project: A full set of service manuals (2003) on e-bay for $90, these manuals give a breakdown of how things come apart and go back together. Several hours at the computer reading posts in this forum and at the Chevy Avalanche Fan Club http://www.chevyavalanchefanclub.com. Those boys in the Avalanche fan club are ambitious and determined. But I learned a whole bunch reading all posts pertaining to navigation radio. | Were can i find reset instructions for tech-2 i have same system and the dealer can not activate system for me, all i get is the theaf activation screen, please help some one any one thanks..are give me the phone number to a cadi dealer that knows how to fix this, so my local dealer can call their tech deptment thanks |
01-05-05, 11:17 AM
| | Cadillac Owners Fanatic | | | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio Reset Instructions
Document ID# 1275527
Radio Setup (With RPO UM8)
Radio Theftlock Clear Procedure
Complete the following procedure, using a scan tool, in order to properly set up communication:
1. At the Main Menu screen, select: Diagnostics.
2. At the Vehicle Identification screen, select the following options:
* Model Year
* LD Trk, MPV, Incomplete
3. At the System Selection Menu screen, select: Body
4. At the Vehicle Identification screen, select the following:
* Appropriate model
* Appropriate Air Conditioning
* Navigation Radio
5. At the Body Screen, select: Navigation Radio.
6. At the Radio screen, select: Special Functions.
7. At the Special Functions screen, select: VIN Relearn.
8. At the VIN Relearn screen, the scan tool will display "Do you want to clear radio theft information?"
9. To begin clearing, press the soft touch key on the top right of the scan tool. The scan tool will display "Clearing Radio Theft in Progress."
10. Press EXIT on the scan tool and cycle the ignition.
Important: The radio theft will learn the VIN. Without learning the VIN, the radio will display a locked message (LOC or LOCKED). |
01-05-05, 01:49 PM
|  | Cadillac Owners Member Cadillac(s): BLK 07 ON 26's | | Join Date: Dec 2004 Location: Lancaster, CA | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio wow thank you so much going to the dealer right now, got my fingers crossed |
01-05-05, 03:04 PM
|  | Cadillac Owners Member Cadillac(s): BLK 07 ON 26's | | Join Date: Dec 2004 Location: Lancaster, CA | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio went to dealer again, still no go. the problem is not the procedure its my model number 10377531 is not listed as a radio choice in their tech 2 computer, so i told the guy maybe he needs a software upgrade, he said it says upgraded its always on line(yea rite) so i will try another dealer thanks for the help.. |
01-06-05, 01:27 PM
|  | Cadillac Owners Member Cadillac(s): BLK 07 ON 26's | | Join Date: Dec 2004 Location: Lancaster, CA | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio Finally got it working great instructions people at cadillac didnt have a clue, went to a gmc/chevy dealer guy had nav working in 30 seconds, i didnt believe it, thanks again |
01-06-05, 04:51 PM
| | Cadillac Owners Fanatic | | Join Date: Aug 2004 Age: 49 | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio Glad it finally worked out for you. It's amazing how many dealers have no clue how to clear a vin even though they have the tech II. Forget about trying to tell them that they are wrong and that it can be done with a tech II, etc, etc. Haveing done five of these and knowing that it takes thirty seconds as I have posted earlier, I have to shake my head when I read posts like yours. By the way, what did they charge you? Average is about $50 bucks from what others have said. Touch screen is nice, isn't it?
01-07-05, 12:44 AM
|  | Cadillac Owners Member Cadillac(s): BLK 07 ON 26's | | Join Date: Dec 2004 Location: Lancaster, CA | | | Re: Need Part Number 2005 Escalade Touch Screen Nav Radio touch screen is great, guy at gmc/chevy dealer didnt charge me dime, jus asked me to come their for service i told him ok..lol | | Cadillac Discussion Tools | | |
Censor is ON | | | |
