How to Seafoam?
Results 1 to 8 of 8
Like Tree1Likes
  • 2 Post By curls
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, How to Seafoam? in Cadillac Escalade Forums; I know there's a ton of instructional videos out there, but I am having a hell of a time getting ...
    curls is offline Cadillac Owners Member
    Automobile(s): 2003 Pearl EXT
    Nov 2010
    33
    1
    QuestionHow to Seafoam?
    I know there's a ton of instructional videos out there, but I am having a hell of a time getting mine done. I just got my 2003 EXT and I'm not sure how it's been cared for. It runs a bit rough and the oil definitely needs changing but I was hoping that with all the great talk I've heard about seafoam I could possibly clear up some of the problems. Anyway, low and behold I can't find the brake booster line. The only line that I've seen that runs from right in front of the steering wheel on the firewall runs down to what looks like the power steering fluid. Which is also dirty. I also have no idea how to start taking the plastic off to get to the TB so I can spray it down.
    Caddydude420 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    215
    Re: How to Seafoam?
    I'd like to see the same...
    Silver04 is offline Cadillac Owners Fanatic
    Automobile(s): 04 ESV
    Jan 2009
    Minnesota
    201
    Re: How to Seafoam?
    I have found this write up pretty comprehensive
    http://www.ls1tech.com/forums/genera...-your-car.html
    oldworld is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 Escalde, 2007 DTS
    Nov 2007
    Lancaster County, PA
    532
    Re: How to Seafoam?
    Does it matter how many miles are on the vehicle to be safe?
    same to use on a 50k motor as well as 200k motor??
    THANKS
    HAPPY THANKSGIVING!!!!
    GrippinGrain is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade EXT, 1999 GMC Yukon Denali, 1986 Toyota AE86
    Apr 2010
    THE DUKE CITY!!
    36
    75
    Re: How to Seafoam?
    Ive Sea-Foamed all of my vehicles. And ive NEVER used the brake booster line! All you need is a line with good vaccum.
    On my 05' EXT I used the PCV line!
    Just pull the line off the PCV itself. Its pretty simple, Make sure you let it suck up the Sea-Foam slowly.
    You'll be ok if you just follow the basic instructions!
    bstiffmanofsteel's Avatar
    bstiffmanofsteel is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Jul 2008
    Elmhurst, IL
    38
    1,042
    Re: How to Seafoam?
    dr_whigham is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade AWD
    Apr 2009
    Lafayette, LA
    33
    5
    Re: How to Seafoam?
    Dont forget to grab a can of the deep creep too.
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,034
    Re: How to Seafoam?
    If it's idling rough I agree the first thing to do is a new air filter and clean the throttle body.
    If you want to clean carbon from the intake then use the PCV vacuum line (IIRC the driver side valve cover towards the rear) and SLOWLY suck up seafoam into the line.
    Before you change the oil you can dump a can of seafoam into the crankcase to free up any sticky engine parts. Wait 1000 miles and dump the oil, add a quality oil filter, and fill with clean oil.
    You can also add seafoam to the gas tank to clean injectors.
    Seafoam is good stuff. I use it in all my gas engines....and I swear I don't own stock in the company.
    The above post is my 2 cents....nothing more.
  11. Remove Advertisements
