Bottoming Out after lowering
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Bottoming Out after lowering in Cadillac Escalade Forums; Hi, just installed a ground force lowering kit that included shocks (factory air ride failed) and springs along with the ...
    Hetiloak is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Mar 2006
    Clanfield, UK
    44
    19
    Hi, just installed a ground force lowering kit that included shocks (factory air ride failed) and springs along with the relevant bumpstops. Problem i have is that even with NO 3rd row seats installed the vehicle bottoms out with a massive thud over the smallest road undulations. I dont want to attempt going out with the kids in the back as the extra 300-500 load will surely end up damaging the back end?. The noise when it hits is almost apocalyptic!! Any suggestions on where to look for issues?
    nathanjax's Avatar
    nathanjax is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 esKONali
    May 2004
    Jax, FL
    36
    1,099
    Re: Bottoming Out after lowering
    You will NEED to do the free travel mod which is cutting off the rear bumpstop brackets for additional travel
    You can see in this picture where my bumpstop was cut off directly above the rear end
    TheCaddyKidd's Avatar
    TheCaddyKidd is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 Cadillac Escalade EXT
    Sep 2003
    New Jersey
    31
    2,090
    I also had a ground force lowering kit and had the same issue although i think they took out the bump stops.. every bump i hit felt like the whole bottom just smashed the ground.. now i got the lift and i sometimes hit the same potholes i hit with the lowering kit and i can barely tell they are there...
    Mar 2006
    Clanfield, UK
    44
    19
    Hi Caddykid,
    when you say "lift".......? How did you raise it?
    Mar 2006
    Clanfield, UK
    44
    19
    Ok i'll look into this. What stops it travelling too far after the mod? Did you use a Groundforce kit? Sorry for the questins but im really concerned that i wont get this sorted.
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Quote Originally Posted by Hetiloak View Post
    The springs stop it from going all the way to the frame... usually. It's not a big deal if it hits though, unless you were to hit it so unbelievably hard that it breaks the axle, but I don't see how that could ever happen...
    No I pieced together my lowering kit.
    Sep 2003
    New Jersey
    31
    2,090
    Hi Caddykid,
    When I sadi lift I was referring to the lift kit I just installed.. I removed the lowering kit from the truck as I couldnt take the ride anymore.. I hated driving the truck with the way it was taking the bumps.. It was just embarassing to be in a Cadillac and everytime you hit a bump it felt the tires flew off.. I'm sure there was something more to it.. When the kit was first installed it was great.. I barely noticed anything but once the parts wore in it was just hell.. I recently went the other way and did a 6 inch lift kit and the ride is back to stock quality.. Now it rides like a Cadillac.. I mean dont get me wrong.. The handling on my truck was great with the lowering kit and sway bars and everything.. It took corners like nothing but in my area you can't drive 20 feet without hitting a pothole so it just wasnt worth it anymore..
    Mar 2006
    Clanfield, UK
    44
    19
    [QUOTE=nathanjax;2396517]You will NEED to do the free travel mod which is cutting off the rear bumpstop brackets for additional travel
    Free travel mod completed. No bottoming out. Thanks for the advice.
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Glad to hear it. Knew it would work.
    T-Giv's Avatar
    T-Giv is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Jun 2008
    Colorado Springs, CO
    28
    216
    Caddykit you still have your drop kit by chance? I'm looking to pick one up and would love to take yours off your hands for ya.
  13. Remove Advertisements
