Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 87
Thread: Air Shocks vs Gas Shocks
  1. #61
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Mark Edward Morrison
    I am in the same boat, my rear shocks and compressor are bad on my 2004 Escalade as well but I don't know if I should go with the air or gas shocks?? My vehicle is worth more with it working like factory and I know the Monroe 40034 is the factory shock made for Cadillac but at $230 a piece for the rear and then a new compressor where as I can buy 4 new Blisten shocks for the same price as one air shock! I mean I really never haul anything in my truck so why do I need the air ride?? I have been debating this over in my head for about a month now and don't know which way to go?
    Here is what you will lose
    Auto leveling
    Real time damping
    Smoother ride(believe me I have rode in trucks with new gas shocks and it's nothing like air ride)
    Resale value may take a hit(not sure)
    The air shocks aren't a bad deal at the price you mentioned.
    The compressor is cheaper at arrnott it is 130 and comes with a dryer rebuild kit.
  2. #62
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Aug 2012
    West Palm Beach, Fl
    234
    Re: Air Shocks vs Gas Shocks
    I tow a boat that with trailer, fuel and gear has me towing 7500#. The trailer is a twin torsion axle with disc brakes on all four wheels. The trailer is rated to carry 9000 # net and GTWR at 10200#.
    Based on my use I have chosen to go with Arnott's Bilstein Air/Gas Shock Combo along with their New Gas Shocks for the front. I also plan to change to their new air compressor. I just today had the opportunity to ride in a 2004 Escalade that the owner had made this change with....the difference in ride quality and smoothness as well as stability as compared to mine was dramatic.
    I will soon give you guys a first hand review of how this system performs in a 2005 ESV AWD towing a 7500# boat with 400# tongue weight. Stay tuned.
  3. #63
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    OK...Before I pull the trigger on this I have to ask a question of those who know more of this than I do.
    My 2005 ESV w/106K miles...upon starting after a 15~20 min. stop will run the air compressor for 30~45 seconds....then the compressor stops. At that time I have reached under the rear and squeezed the rubber seal on both rear shocks. They feel flat as if they have no air in them.
    Are the shock bladders supposed to fill with air or is the rubber just a seal between the top and bottom of the shock? Is the compressor running until it over comes a low air condition then it stops? I get no ECU trouble codes.
    I guess there might be a run timer that turns the compressor off during each ignition cycle if correct air pressure is not achieved....I'll call Arnott and get their answer on this also.
    I don't mind spending the money to correct an issue but I hate like hell to spend it un necessarily.
  4. #64
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by sprink60
    Sounds normal so unless you get the service ride control message and codes don't worry.
  5. #65
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,812
    You should be able to feel the bag pump up that is the bag not a cover, the compressor senses the suspension not moving via the sensors and shuts off... Mine has been doing this for about 4 months then the compressor finally went out so my whole air ride is shot however i have not had any trouble codes or error messages what so ever
  6. #66
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    OK...talked to Arnott...the compressor is timing out and the bladders are not filling because there is a leak. I ordered OEM replacements with a lifetime warranty for $369 to my door + core deposit. Stay tuned....should receive tomorrow.
  7. #67
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    Sweet
  8. #68
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    UPDATE...I received the shocks from Arnott late yesterday. I had them installed this AM and dove about 50 miles under different conditions. The Escalade is very stable and smooth...a big improvement...especially at highway speeds (80+ MPH). Previously I would experience a bit of sway but now it is very tight and smooth. On rough surface streets it feels like I just fly over the bumps as compared to the way it was previously.
    The next test is with the boat...pulling 7500#...stay tuned.
    So far so good.
  9. #69
    2MCHPWR is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade
    May 2008
    NY
    29
    Sprink - thanks for the update. i need new rear shocks for towing too. Did you get the $369 Bilstein shocks or the $379 remanufactured OEM shocks?
    Just curious which ones you went with. Another thread in here said the remanufactured OEM ones aren't fully rebuilt. Just new air bags.
    Do the new shocks come with the air lines that hook up to the compressor? i'm concerned that my lines might have holes but I don't know if they come when you get the new rear shocks.
  10. #70
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    So far so good.
    Yo sprink lets see a pic of the escalade and the boat
  11. #71
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    Quote Originally Posted by 2MCHPWR View Post
    I got the OEM Re- Furbished...direct replacement...shocks only, no lines. They have all of the original connections...no mods required. They are having a 10% off sale now.
    Oh...they also have a Lifetime Warranty which considering Arnott has been around since 1954 is worthy of consideration..
  12. #72
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    Quote Originally Posted by wesyder View Post
    Check this thread.
    http://www.cadillacforums.com/forums...-2005-esv.html
  13. #73
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    Nice setup i remember seeing that pic
  14. #74
    Yoneytan is offline Cadillac Owners Member
    Automobile(s): Escalade
    Aug 2012
    44
    10
    can anyone tell me if this applies to a 2007 yukon denali? i have both an 07 denali and a 08 escalade, my denali has 120k miles and is riding like crap with regards to suspension.feels like the shocks are bad, could it be the air pump or is it the shocks? was considering replacing them but at a cost of roughly $950 for parts only theres no way, i'd either sell the truck or replace with gas shocks if possible. any help is appreciated.
  15. #75
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    Quote Originally Posted by Yoneytan View Post
    Go here https://www.arnottindustries.com/par...d6_pid150.html
    Same exact part No. for the rears.
  • You may not post replies
