Air Shocks vs Gas Shocks - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 87
Like Tree3Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Air Shocks vs Gas Shocks in Cadillac Escalade Forums; looking for some guidance...looking to replace my current air shocks with oem replacements from Arnott industries. Any reason that i ...
  1. #31
    fitz13 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Escalade ESV
    Nov 2010
    46
    9
    Re: Air Shocks vs Gas Shocks
    looking for some guidance...looking to replace my current air shocks with oem replacements from Arnott industries. Any reason that i should also add, for less than $100.00, the air lift 1000 ones - mentioned in one of the other threads? Will this affect/damage my factory air ride?
  2. #32
    nathanjax's Avatar
    nathanjax is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 esKONali
    May 2004
    Jax, FL
    36
    1,099
    Quote Originally Posted by fitz13 View Post
    There's no real point to have the Airlift helper bags if your stock bags and system are working properly. When you put a load on your factory suspension, it should raise the rear back up to factory height, the same thing that would be done with the airlift.
    Same thing, just 2 different ways of doing it.
  3. #33
    Nov 2010
    46
    9
    Thank you for the quick response. Unfortunately, i did nhave one more question...if i go with the Arnott Remanufactured O.E.M. Electronic Rear Air Shock, will i need to bring to Cadillac to be "re-programmed"?
  5. #34
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    No cause nothing is programmed. Just a simple swap
  6. #35
    roboteacher is offline Cadillac Owners Fanatic
    Oct 2009
    111
    I put the Airlift 1000 in today. It kicked my ass (3-1/2 hours on my back, I feel like a cheerleader at prom). It's by far the best this truck has ever rode. I put a regulator in line so I don't over-fill. What a great mod.
  7. #36
    Nov 2010
    46
    9
    ok, so good news...bad news! Shocks don't leak, airlines no leaks. Dealer has no idea what could be wrong? When i got off the phone with service, the last thing he mentioned was that it could be an auto height level sensor, not funstioning properly? Not sure what that means...so looking for more guidance. Oh yeah, they also found leaking engine oil cooler lines and sterring length/pitman arm something...$1000.00 to be exact...ugh!
  8. #37
    Oct 2009
    111
    Kinda like Joe Peshi (they FU*& you at the drive through), they FU*& you at the dealer. I took a jumper to the relay to make sure the compressor could be powered up. Once that was done and I did all that you did, I removed the compressor, put it on a bench and found an issue with the solenoid vavle attached to it. I bought a new system from Arnott (has the new solenoid attached) and it worked great until my shocks started leaking. After I found out how much it cost to replace all the shocks, I decided to replace everything and have never been happier. It rides great without the worry of when it was going to fail again.
    Good Luck
  9. #38
    MattC04 is offline Cadillac Owners Member
    Jan 2006
    30
    Where did you buy them for $235. and no shipping?
  10. #39
    Oct 2009
    111
    The web site and part numbers are in this posting. They are on the first tab of these. I hooked up the trailer yesterday (a loaded 8.5' x 20' trailer) and it didn't sag a bit. I've never been happier with a vehicle mod.
  11. #40
    nohopeboyz is offline Cadillac Owners Member
    Automobile(s): escalade
    Nov 2010
    15
    my SSS light comes on too... Please help..
  12. #41
    bowanna03 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Jul 2010
    40
    23
    I completed the swap yesterday also and am still gettign the SSS light, is there anything that can be done to remove I pulled one RTD 30 amp fuse.
  13. #42
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Quote Originally Posted by bowanna03 View Post
    Did you swap front and rear shocks? Did you unhook your battery, pull fuse, remove and replace all 4 shocks, and then replace battery cable?
  14. #43
    Jul 2010
    40
    23
    Yes, I replaced all four and did the battery and also pulled the fuse. I left the battery disconnected for an hour. Is it possible i have another code too. I am hearing a noise in the front end that sounds like a pump kickin on like ABS or brakes after I go more than 5 miles an hour it goes away, could that be it?
  15. #44
    robmick is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    8
    Do I have to replace all 4? Or can I just replace the rears??
  16. #45
    96Fleetwood's Avatar
    96Fleetwood is offline Auto Enthusiast
    Automobile(s): 1992 Eldorado Touring
    Jul 2005
    Naples, FL
    37
    3,688
    I hate to bring old threads back.. but to f/up with those who installed these Bilsteins to replace the 'autoride'..... how is it working out?
    I am thinking of doing the same with my Denali and wanted to see how they held up after some use.
    Thanks,
    Elias
    2015 Audi Q7 3.0T S-line - my DD
    2013 BMW Alpina B7 - wife's DD
    2002 Pontiac Trans AM WS6 Convertible Collectors Edition
    1992 Cadillac Eldorado Touring Coupe
  17. Remove Advertisements
