Air Shocks vs Gas Shocks - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 87
Like Tree3Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Air Shocks vs Gas Shocks in Cadillac Escalade Forums; Arnott is going to repair my compressor and send it back. The only bad part is the air shocks I ...
  1. #16
    roboteacher is offline Cadillac Owners Fanatic
    Oct 2009
    111
    Re: Air Shocks vs Gas Shocks
    Arnott is going to repair my compressor and send it back. The only bad part is the air shocks I had were leaking and that's what killed the compressor. They said I no longer have a warrentee on my compressor unless I replace my leaking shocks with air shocks from them. I plan on using their compressor with a momentary switch and guage on the dash to fill my future "air lift" system for when I'm pulling my heavy trailer.
  2. #17
    beav626's Avatar
    beav626 is offline Cadillac Owners Fanatic
    Automobile(s): 03 EXT Sold / 11 CTS V Coupe sold / 15 CTS Vsport
    Mar 2010
    Oklahoma City
    37
    142
    This is now on my todo list too
  3. #18
    hamkan is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV Platinim Ed
    Sep 2010
    19
    Thanks guys useful information, have to keep this in mind when I want to change mines
  5. #19
    blazen244's Avatar
    blazen244 is offline Cadillac Owners Member
    Automobile(s): 2008 EXT
    Jun 2006
    maryland
    65
    Thanks guys my pump just died, my compressor just died I was really dreading this nowit looks like i have to replace the rear leaking shocks and the dead pump.
  6. #20
    trodder is offline Cadillac Owners Member
    Automobile(s): Current: 03 Escalade Prev: 01DTS, 98Deville, 89STS, 87Fleet
    Oct 2007
    Minnesota
    72
    the listed shocks make this confusing as to which is the best fit for the escalade. # F4-BE5-6500-H0 is the front for a Yukon or Tahoe but #BE5-6501-H1 is the rear for a Suburban.
    whats the difference? Should we use both front and rear from the Suburban? OR Front and rear from the Tahoe/Yukon? Or the mixed set?
  7. #21
    nathanjax's Avatar
    nathanjax is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 esKONali
    May 2004
    Jax, FL
    36
    1,099
    Quote Originally Posted by trodder View Post
    It's the same, depending on what site your looking at or where you go...
    If you look up F4-BE5-E380-H0 for the rear, some sites say that part number has been replaced by part number BE5-6501-H1. Some sites will let you order the F4-BE5-E380-H0 which is the actual part for the rear of a tahoe.
    The 6500 is the front, the 6501 is for the rear...
  8. #22
    Gale Hawkins is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Oct 2010
    Murray, KY
    66
    63
    http://www.strutmasters.com/Escalade...l-60769-ce.htm
    I had no idea the air bag kit sold for less than $100 for the Escalade
  9. #23
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Quote Originally Posted by Gale Hawkins View Post
    $75 free shipping...
    http://www.amazon.com/LIFT-60769-100...8637315&sr=8-1
    That's where I got mine... makes all the difference in the world
    http://www.cadillacforums.com/forums...installed.html
  10. #24
    yamla_jatt806 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Sep 2006
    46
    70
    Roboteacher - Maybe not everyone is as cheap as you are. I personally love the air ride option, towed a loaded trailer last week and the ride and height of the truck was just fine...did not sag a bit. (2005 Escalade with 70k miles)
  11. #25
    TheItalian is offline Cadillac Owners Member
    Automobile(s): 2002 Cadilac Escalade
    Oct 2010
    30
    hey guys. great thread. small problem on my end. my SRC light was on, shocks were blown and compressor was basically gone. so, i did;
    1. disconnected the battery
    2. removed air shocks, swapped in gas shocks
    3. removed the RTD fuses
    4. reconnected battery
    now my Service stability system light is on, any ideas??
    thanks guys.
    again, great thread. took my under 2 hours on my garage floor
  12. #26
    rdgwinn is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac Escalade & 1973 Eldorado
    Oct 2010
    38
    3
    If your considering doing this, continue reading this post. Picked up my truck today and everything turned out fantastic. Spent $240 on all 4 shocks, followed the other post by pulling the RTD fuse and no service air ride!!!
    Highly recommend
  13. #27
    Oct 2009
    111
    I'm not sure if there is a difference between an 02 and my 04. You said fuses (not fuse)? I only had one fuse to pull.
  14. #28
    MattC04 is offline Cadillac Owners Member
    Jan 2006
    30
    where did you get these shocks for $235 please? Also, any step by step tips :-)?
  15. #29
    Oct 2009
    111
    All the links and part numbers are on the first page of this posting. To change them out, just lift the wheels so there is no load on the current shocks. Unbolt the old units (tie up any wires because you wont need them any more). Insert the new gas shocks and re-install the bolts. Very easy mod. I pulled my fuse and dis-connected the battery before we started.
  16. #30
    Oct 2010
    30
    sorry, yes, just pulled the 1 fuse. RTD. i havent done the front shocks yet so would that make a difference? ive disconnected the battery a few times but still getting the SSS light.
  17. Remove Advertisements
