Escalade headlights
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Escalade headlights in Cadillac Escalade Forums; how do you remove the 03 and newer escalade headlights? a link would be great or some detailed description i ...
    eduardo831 is offline Cadillac Owners Member
    Automobile(s): 2003 escalade
    Dec 2009
    29
    16
    Escalade headlights
    how do you remove the 03 and newer escalade headlights? a link would be great or some detailed description i searchrd but i couldnt find anything. thanks in advanced
    hcubed is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Feb 2009
    72
    Re: Escalade headlights
    Why don't you read your owner's manual?
    Headlight removal for bulb changes starts on page 5-56.
    If you don't have a manual, dowload one at www.pdfcast.org
    Dec 2009
    29
    16
    I know how to take them out to change the bulbs, but I want to take the connection to the HID's out to take the whole light off so i could clean it. I dont want to start pulling on wires and break something. There is a connection that comes in through the bottom of the assembly I think it comes from the balast to the HID's this is the only thing holding the headlight at this point.
    shore is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade
    Nov 2008
    Port Orange, Florida
    44
    637
    Remove plastic shroud on top of grille.several push pins.
    Remove grille.One bolt and it lifts out.
    Each headlight has two "L" shaped pins.1 on top and 1 on the side.Pop them away from the headlight(they sit in a clip) and pull them out.Hold the light it might fall forward.
    There is a wire harness to the HID ballast on the grille side of the light housing.1 has a little colored clip.Just pop it off.Then undo the harness.Now the main harness in on the bottom of the headlight housing.Flip it over and undo it.
    It's very easy.Don't drop it.If you're trying to clean the lens out with water just take one of the bulbs out.Don't bother with the HID as it's a bitch.Let the water drain out the wire harness connection.
    d3adpool is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Apr 2010
    North Louisiana
    34
    82
    what about if you decide to clear your headlights, how do you remove the HIDs?
    mosimann is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade EXT
    Jul 2010
    41
    64
    What do you mean about removing hids? It's really easy to disassemble everything, remove the bulbs, unplug the ballast, etc.
    Apr 2010
    North Louisiana
    34
    82
    Quote Originally Posted by mosimann View Post
    i dunno, some ppl say its a "bitch", some say its easy to remove the hids and all the wire harnesses from the housing. Which is it?
    00buck86 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade 2WD
    Mar 2011
    30
    3
    Quote Originally Posted by d3adpool View Post
    wow I wish somebody would've answered the damn question. I'm having the same problem. That cable that people are saying "just disconnect it" can't be! or so it seems. I also need help on this because I'm trying to swap my headlight housing to a new one. The HID cable had a metal clip around it that I removed and beneath it is a black plug that plugs to the HID light but I can't remove it. I've tried screwdrivers, needle nose pliers, and brute force. I need that cable removed and no one on the net knows how. Please help; someone must know (and for God sakes please don't say look in the manual because it tells you to take it to the dealer - F that!).
    Mar 2011
    30
    3
    well in case someone's searching for this in the future, I found a way that may not be the most desirable way to do things. I simply cut the cable. There are 3 layers of shielding for this cable (one rubber two threaded). Beneath that there are three wires that are color coded. If you're switching headlight lenses or just want to clean them you'll have to couple them back together. I recommend using reusable ones. If anyone has a detailed better way to do this, please add to.
  12. Remove Advertisements
