What's the largest 20" tire I can fit under a 2000 Escalade?
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, What's the largest 20" tire I can fit under a 2000 Escalade? in Cadillac Escalade Forums; I've got 20" Torque Thrust ST's I'm putting on a 2000 Escalade, what's the largest tires size I can go ...
    VIPERBLUELX is offline Cadillac Owners Member
    Aug 2004
    4
    I've got 20" Torque Thrust ST's I'm putting on a 2000 Escalade, what's the largest tires size I can go with? 275/55/20?
    Xrayqueen's Avatar
    Xrayqueen is offline Cadillac Owners Enthusiast
    Aug 2004
    Yucca Valley,California
    512
    TalkingRe: What's the largest 20" tire I can fit under a 2000 Escalade?
    I'm rollin with Goodyear P285 50R 20 and Devinci Havac's rims. No rubbin just lots of looks
    Peace
    DeL2000 is offline Cadillac Owners Member
    Jul 2004
    Oxford UK
    50
    You could probably use up to 45,check with the tire dealer, they can tell you what's the max for a 20 inch wheel for a Lade. Currently I'm using 275/55/20
    skides1's Avatar
    skides1 is offline Cadillac Owners Enthusiast
    Mar 2004
    Seattle
    508
    Viper,
    Toyo Proxes has some HUGE tires! I have a friend with 325/50/20's on an Excusion and it is very HUGE![URL=http://http://www.1010tires.com/tire.asp?tirebrand=Toyo&tiremodel=Proxes+S%2FT&pc= 242340]
    The Pic doesn't do them justice. That size will probably rub. I am going with the 305 45/20's . 285/50/20 matches the fact diameter and are about 12"s wide-they look best on 20x10" wheels-the 325/50/20's will alter your speedo due to the increased height. 325=325mmwide, 50 means 50% sidewall height of 325, 20=rim size. I hope that made sense
  7. Remove Advertisements
