Service airbag..GRRR
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Service airbag..GRRR in Cadillac Escalade Forums; I hardly drive my 05 escalade, only on weekends. I started it up yesterday and it threw a "service airbag" ...
    sillyboi's Avatar
    sillyboi is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2008
    58
    I hardly drive my 05 escalade, only on weekends. I started it up yesterday and it threw a "service airbag" message on my cluster. I already tried pulling the negative from the battery to reset it, but no luck. The battery is new btw. Since I'm at 77k miles, I no longer have warranty, I also called the stealerships and they told me they charge $120 to scan it. WT#@%!%^@!
    Also, the passenger airbag turns on/off when there's a passenger present.
    Please help..
    If anyone is in the Socal area and have a scan tool or know any reputable shops beside the stealers, please let me know!
    Thank you all.
    shore is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade
    Nov 2008
    Port Orange, Florida
    44
    637
    Re: Service airbag..GRRR
    Most of the time it is one of the impact sensors up under the front bumber.They aren't free but not bad.
    sillyboi's Avatar
    Apr 2008
    58
    yeah I read about others having issues with those sensors. Yeah price is not bad at all. Can I use a voltmeter to measure any resistance on the impact sensor that will determine if its going bad?
    Nov 2008
    44
    637
    If you find out how to test them let me know....I have the light on also.I've checked everything else but have yet to come across a cheap sensor to replace it.
    They are both the same.
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    I had the same problem.... ended up buying a new sensor on ebay for $45 shipped.... worked great! Its a very common problem on these trucks.
    sillyboi's Avatar
    Apr 2008
    58
    So I guess I really have to pay that ridiculous $$ to get it scan by the stealers..anyone?
    Oct 2008
    Long Island
    29
    1,363
    They scanned mine for free.... just pretend you want to get it fixed but go towards the end of the day and tell them you only want it scanned. I did this twice at 2 different caddy dealerships (first time was for a suspension problem).... worked both times, if not.... it should only be a 1/2 hr labor (it literally takes 5 mins, they did it in front of me).
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I had the dealer scan it to confirm that the sensor was bad, then I replaced them both myself. They are a bit of a pain to replace, but it was a easy fix!
    sillyboi's Avatar
    Apr 2008
    58
    I found a local shop here in socal that will scan it for $90, bad thing is they only open M-F.
    Caddydaddy, where is the sensors located? Can you post a quick picture?
    Dax
    Dax is offline Cadillac Owners Member
    Automobile(s): Escalade
    May 2010
    23
    Not the best picture(s), but the installation procedures mention the radiator support as a mounting position.
    Hope this helps.
    sillyboi's Avatar
    Apr 2008
    58
    thanks a bunch
    Oct 2008
    Long Island
    29
    1,363
    with a ratcheting 10mm, it only takes 4-5 mins to take it off and put a new one on.... nothing to take off, just crawl under the car and take it out, simple.
    sillyboi's Avatar
    Apr 2008
    58
    thanks luxurylife33, I will update once I get it scanned.
  16. #14
    Nov 2008
    44
    637
    super simple to change.
  17. #15
    Caddydude420 is offline Cadillac Owners Fanatic
    Nov 2006
    215
    I had that light come on on my truck. I brought it to one shop, they said they scanned the computer and it was a bad "hook flash sensor" or something like that. Its in the steering wheel and keeps electrical contact when your turning the wheel. It was $200-300 part and 3 hours. I didn't want to spend that so I drove it for a year.
    I took it to another shop. They did a little investigation and found out it's a bad connection by the drivers feet. It's a common problem, a little moisture gets into it, it corrodes and throws the code. You can either get a several hundred dollar replacement part, OR you can do what the shop did and just cut out the connection and solder/connect the wire back.
  18. Remove Advertisements
