right rear parking light inop
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, right rear parking light inop in Cadillac Escalade Forums; I have an 04 Escalade. I lost my rear parking light on the right side. I tracked the problem down ...
    c1smalley is offline Cadillac Owners Member
    Automobile(s): Escalade ESV
    Sep 2009
    49
    6
    I have an 04 Escalade. I lost my rear parking light on the right side. I tracked the problem down to a junction box right behind the right rear tire. There is 4 wiring harnesses that come into this junction box with multi pin plugs... 1 pin is rotted off... alot of corrision...
    What is that junction box called and how much for a new one.
    Thanks
    Chris
    Sep 2009
    49
    6
    TalkingRe: right rear parking light inop
    63 people read my post and no one has had this problem... I feel special!!!
    I went to the Caddy dealership and purchase a new electrical distribution block for the tail lights $37.07... Not to bad.... Easy fix... Problem solved
    Thanks to every1 who looked..
    Chris
    Lente is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    20
    I am having the same problem so I guess I will try that too. My brake and blinker work fine just no tail lights at night on right side. How exacty does that lil plugs come off I pulled the plasitic clip but it still wont budge thanks.
    1967bigdaddy's Avatar
    1967bigdaddy is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    Dec 2009
    Hogansburg NY 13655
    50
    37
    Lente: it probably has dirt build up right near the release on the plug. That is a common problem, if you had acess to a compressor I would blow some air at the plug and try again.
    slidewayz is offline Cadillac Owners Member
    Automobile(s): escalade
    Jan 2012
    13
    Okay so my right rear light is doing the same thing brake, turn, reverse work but the damn park does not.....i have gotten pulled over twice for it and replaced the whole tail light housing cause i thought thats what it was but nope......so here i am the box was every hard to get the plugs unplugged but i did so and the bottom middle one had water in it and green stuff seeped out it.....(sounds like a bad collage conversation) but either way im gonna get a new box but do you thing the plug going to the box is bad also????
  8. Remove Advertisements
