Tune-up made my 03 more sluggish??
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Tune-up made my 03 more sluggish?? in Cadillac Escalade Forums; Just purchased a new/used 2003 Escalade for the wife. Here is something that has me beat, it has 135,000KM on ...
    McLovin Guest
    Just purchased a new/used 2003 Escalade for the wife. Here is something that has me beat, it has 135,000KM on it so I thought I should give it a tune-up, as there is a bit of a vibration at idle. Put all new plugs (AC Delco part# 41-110 left factory gap), new NGK spark plug wires, new fuel filter and a new K&N drop in air filter, full tank of Premium and some Lucas fuel treatment. Now after I am done the truck seems to run smoother but it seems more sluggish than before. I thought it was just me, but now without me saying anything to the wife she said the Escalade feels slower than before i "fixed it". Now I am really stumped... Anyone have a rational excuse for this, or are we BOTH crazy? And to top it all off the vibration is still there at idle, just not as noticeable.
    CEPMAN is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Escalade ESV
    Jul 2009
    NC, USA
    36
    360
    Re: Tune-up made my 03 more sluggish??
    Did you clean the throttle body? How's the trans fluid looking?
    McLovin Guest
    Is there a throttle body on a 6.0L? Either way it seemed more responsive BEFORE I did the work to make it better. One thing is that the old spark plugs had a larger gap, and I would assume this is just due to the electode being worn down as they werr original plugs. Maybe the factory set gap is not enough??
    Jul 2009
    NC, USA
    36
    360
    Yes you have a throttle body.
    Sometimes a dirty one can cause a little sluggishness. If everything is dirty/worn/needing replacement, then they'll kinda be in sync (kinda like all your clothes being dingy) but when you start replacing things, it brings more attention to whatever else needs to be replaced (kinda like wearing a crispy white shirt and some dingy white pants and shoes.)
    To find your throttle body, follow the air intake to the engine. Remove the intake connection there, and you'll see the throttle body. There will be the cable connected to it that goes to your gas pedal.
    The throttle plate should be shiny. If it isn't, then it should be cleaned. You can get some throttle body cleaner for like 3 bucks at the auto store, and cleaning it takes like 5 mins. That might help.
    bizzob223 is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade ESV Platinum
    Feb 2010
    Michigan
    75
    This may be a shot in the dark, but have you disconnected the battery yet? I know on my impala I would always disconnect the battery to allow the ECM to reset when I changed plugs and such. Usually 1 hour did it for me, should let the ECM relearn the engine parameters.
    Bob
    McLovin Guest
    Quote Originally Posted by bizzob223 View Post
    Bob
    I will try this, sounds logical to me.
    goglas is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade AWD
    Mar 2010
    Orlando Florida
    9
    You said that you left the factory gap on the plugs. They can change while in the boxes, from banging around in shipping. Make sure that you check all the gaps to insure the proper one was maintained.
    McLovin Guest
    Anyone know what the proper Gap should be for the 6.0L?
    sk7's Avatar
    sk7
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    Ignition System Specifications
    Application Specification Metric English
    Firing Order 1-8-7-2-6-5-4-3
    Spark Plug Wire Resistance 1000 ohms per ft
    Spark Plug Torque 15 N·m 11 lb ft
    Spark Plug Gap 1.52 mm 0.060 in
    Spark Plug Type 25171803 [AC plug type]
    12567759 [NGK plug type]
    CutNpaste info from the service manual. There's also this TSB:
    Information on New Spark Plugs and Gapping #03-06-04-060 - (Oct 24, 2003)
    2004 Buick Ranier
    2002-2004 Cadillac Escalade, Escalade EXT
    2003-2004 Cadillac Escalade ESV
    2004 Cadillac CTS-V
    1997-2004 Chevrolet Corvette
    1998-2002 Chevrolet Camaro
    1999-2004 Chevrolet Silverado
    2000-2004 Chevrolet Suburban, Tahoe
    2002-2004 Chevrolet Avalanche
    2003-2004 Chevrolet Express, TrailBlazer
    1999-2004 GMC Sierra
    2000-2004 GMC Yukon, Yukon XL
    2001-2004 GMC Yukon Denali, Yukon XL Denali
    2002-2004 GMC Sierra Denali
    2003-2004 GMC Envoy XL
    1998-2002 Pontiac Firebird
    2004 Pontiac GTO
    2003-2004 Hummer H2
    with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
    A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
    McLovin Guest
    I have found online that Ac Delco #41-985 has been replaced to #41-110. Although I have not confirmed this with GM.
    Mar 2010
    Orlando Florida
    9
    The auto parts store where you bought the plugs will let you know the proper gap.
    Mar 2010
    Orlando Florida
    9
    Did the problem ever get corrected?
    Silver04 is offline Cadillac Owners Fanatic
    Automobile(s): 04 ESV
    Jan 2009
    Minnesota
    201
    MAF sensor cleaned?
  16. #14
    McLovin Guest
    Yes the problem seemed to correct itself. the rougher idle has also slightly returned, but the power is back. I did so many things, I am not sure how I fixed it.
  17. #15
    GrippinGrain is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade EXT, 1999 GMC Yukon Denali, 1986 Toyota AE86
    Apr 2010
    THE DUKE CITY!!
    36
    75
    My rule of thumb on spark plugs is if you have to gap em you got the wrong ones! You should be running either AC-Delco Platinum, Iridium Plugs only!
    Also I would suggest pulling off that MAF and getting a can of CRC MAF Cleaner and cleaning that bad boy, Also clean the throttle body!
    One last thing I would suggest is Sea-Foaming it! I Sea-Foamed my 2005 EXT and what a huge difference! Im telling you the truck was smoking like a chimney!! There was so much carbon build it was rediculous. Doing this procedure you'll notice a much smoother idle and power increase!
  18. Remove Advertisements
