Eliminating brake dust????
Results 1 to 15 of 15
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Eliminating brake dust???? in Cadillac Escalade Forums; i have seen those disk brake simulators that go behind the rims and make it look like you have a ...
    99 SKALAID's Avatar
    99 SKALAID is offline Cadillac Owners Fanatic
    Feb 2004
    california
    37
    376
    i have seen those disk brake simulators that go behind the rims and make it look like you have a big ole disc brake.... but how about something that is all black so the brake dust doesnt go onto the rim?? anyone??
    slimm44 is offline Cadillac Owners Enthusiast
    Apr 2004
    WA-VA-USCG
    33
    527
    99 SKALAID's Avatar
    Feb 2004
    california
    37
    376
    Re: Eliminating brake dust????
    says it wont fit a 1999 or 2000 escalade and they dont make them up to a 23 :rolleyes2
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,307
    The Escalade's have ceramic brake pads, I believe that this was switched in 02' or for sure 03', my 03' makes no brake dust, however it takes much more brake pressure to stop larger wheels, so you will get more dusting. You may want to switch to ceramic pads when you need brakes.
    Daryl in KY's Avatar
    Daryl in KY is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade
    Jan 2004
    Western Kentucky
    66
    159
    Skalaid,
    Get some EBC 6000 brake pads. They have almost no dust and help the brake performance.
    99 SKALAID's Avatar
    Feb 2004
    california
    37
    376
    Quote Originally Posted by Daryl in KY
    Skalaid,
    from where please
    T_Dogg8's Avatar
    T_Dogg8 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade EXT 2003 CTS
    May 2004
    PA
    2,860
    aren't they harder on your rotors and only work really well if your brakes are hot??
    Jan 2004
    Western Kentucky
    66
    159
    Quote Originally Posted by 99 SKALAID
    from where please
    Sorry for not replying sooner, I've been out of town.
    I got mine from Tire Rack. I also replaced the front rotors with a set of cross drilled Bemco rotors (from eBay) and replaced the rubber brake hoses with steel braided hoses. The rear drum brakes were adjusted, but are stock. The brake pedal response is much firmer and the brakes grab very well in a panic stop. I don't have anything close to the dust that I had from the stock pads. I am very pleased with the performance considering the cost was under $400 including installation.
    T_Dogg8's Avatar
    May 2004
    PA
    2,860
    under 400 for all of the work??
    Jan 2004
    Western Kentucky
    66
    159
    The pads were around $70, the brake lines around $90, the rotors were $100 on eBay. I was having the Lade serviced, aligned, and the front bearings repacked. Installing the new rotors, shoes, and hoses wasn't a big labor cost.
    outofdablue is offline Cadillac Owners Fanatic
    May 2004
    Philadelphia
    411
    There is no such thing as "less brake dust". If you think about it, your pads, whatever they are made from will wear down after you. With this in mind, how can you have "less" dust if they wear down. The pads with "less" dust only mean that they are made of a different color material. They use a material that is not black. All brake pads are gonna wear and leave little bits and pieces of the material they are made of, so when those bits and pieces are say a silver color rather than black you get the "less" brake dust look.
    Jan 2004
    Western Kentucky
    66
    159
    Quote Originally Posted by outofdablue
    You can explain it however you want to. I don't have the grungy black dust on my front wheels that I had with the OE pads. The front wheels look like the rear wheels, with road dirt being the major contaminent on the wheels.
    joshuap is offline Cadillac Owners Fanatic
    Automobile(s): Escalade EXT
    Apr 2004
    196
    Where did you get the brake lines?
  16. #14
    T_Dogg8's Avatar
    May 2004
    PA
    2,860
    don't some brake pads come in harder material that doesn't break down as fast??
  17. #15
    Jan 2004
    Western Kentucky
    66
    159
    Quote Originally Posted by joshuap
    I got the brake lines over the internet, but I don't remember which parts place that I ordered them from. I believe it was from a parts supplier from Indianapolis. However, The Tire Rack carrys them now. At the time that I ordered the ones that I have, most places did not have them in stock. The ones that I got were listed for the Escalade, but I believe they were intended for raised vehicles as they are a couple of inches longer than I think they need to be. I would suggest that a little research would be a good idea to make sure that they are intended for unaltered height. I have had mine for a couple of years and everything is working OK, I just keep an eye on them when I service, rotate tires, etc.
    T Dogg8,
    On the Tire Rack site, there is a description for the EBC pads. It tells about brake dust and the properties of the pad material. There are other places that describe the effect of pad material on brake dust. The OE pads are a compromise between cost and performance. I'm sure that the brake conversion packages that are so popular do not use the same pad material as the OE pads on the '99 & '00 Lades. I understand that the later models have improved pad material, but I haven't seen anyone talk about the dust on the newer models. I suspect that the newer models do not have the same dust issue as the older ones.
  18. Remove Advertisements
