DIY: How to add the platinum heated/cooled cupholders to your 03-06 Escalades and EXT
Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 15 of 97
Like Tree3Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, DIY: How to add the platinum heated/cooled cupholders to your 03-06 Escalades and EXT in Cadillac Escalade Forums; I bought the heated/cooled cup holders from a 05 Platinum off eBay for $122. The swap is very easy and ...
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    I bought the heated/cooled cup holders from a 05 Platinum off eBay for $122. The swap is very easy and straight forward. I did not have to trim or cut anything to get it to fit in my EXT. There are only three wires - constant 12+, ignition 12+, and a ground -.
    First remove the front radio pop panel (pops out). Remove the front cd changer panel + the cup holder. These panels just pop out, no screws. Remove the 2 screws the hold in the CD changer. You need to move it out of the way, no need to unplug any wires. You will also have to take off the center console lid (phillips screws).
    You'll find a whole bunch of business cards and bank receipts you've lost.
    Get a BBQ lighter and melt the tabs. 10-15 seconds got them soft enough to lift. (the one on the right is melted open)
    Door lids screw off with 9/32 socket.
    Final result (03-04 wood grain swapped)
    Connect the red to +, blue to ignition +, and black to ground. Put fuses on the 2 + lines. Tap the + wires off the ignition (more usable amps). Dont start hacking the amp or cigarette lighter wires because they make not provide enough amps for both to function.
    The heated/cooled plates actually work! They get REALLY cold and REALLY hot. Not really enough to burn you, but def enough to keep your coffee hot.
    GIINOVA and Its_finessed like this.
    ce8204 is offline Cadillac Owners Member
    Automobile(s): 2012 SRX
    Apr 2007
    32
    Re: DIY: How to add the platinum heated/cooled cupholders to your 03-06 Escalades and
    I like it ! & now i want it ! well done & the fused links look good-
    now, the real question.... do they REALLY work well?
    bstiffmanofsteel's Avatar
    bstiffmanofsteel is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Jul 2008
    Elmhurst, IL
    38
    1,042
    Great job and write up! Keep up the good work!
    shore is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade
    Nov 2008
    Port Orange, Florida
    44
    637
    Can you show us which 3 wires you tapped into?
    Oct 2008
    Long Island
    29
    1,363
    Quote Originally Posted by shore View Post
    For the 03-04 Escalades the 12v + constant at the ignition is the RED or RED/WHITE wire. The 12v + Ignition is Pink. Just probe with a test light to make 100% sure. This worked on my 2003 Escalade after looking at the diagram. For the ground I just wrapped it around an amp mounting bolt.
    Use this site to check for yours....
    http://64.85.6.118/diagrams/diagrams.asp
    nathanjax's Avatar
    nathanjax is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 esKONali
    May 2004
    Jax, FL
    36
    1,099
    I got mine yesterday, plan on installing them tonight!!! (Yes, Christmas night at 10pm)
    I tested mine, and they both cool and heat fine...
    Looks like mine is missing the flaps on the rear of the cupholder though... and maybe the buttons or something in front of the cupholder? Maybe little rubber bumps for the lids?
    Lux, what are those? are they buttons or something?
    04EXT_3699 is offline Cadillac Owners Member
    Automobile(s): 04-EXT
    Jul 2009
    15
    hey!!! i have had trouble getting you a message...i dont know why!!!...i will take the cup holder!!! thanks!!!!
    ....and the little rect bumpers if you will part with them also!!!
    let me know about the paypal, get back with me thru the PM and we will get this to be a done deal!!!
    thanks again,
    tim
    Jul 2009
    15
    do i need any other pieces ............
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Quote Originally Posted by 04EXT_3699 View Post
    thanks again,
    tim
    email me.. nathanandkatiec@gmail.com
    DONE!!! It took 1 hour, start to finish...
    Couple pieces of info I think I should share...
    I have had 5-6 years of experience doing car stereo installation and other misc fabrications... This is NOT for the faint of heart. If your not ready for a BIG challenge, don't do this yourself. You your not ready to go purchase a new center console piece because you might mess it up, don't do this yourself. Take your time, DON'T CATCH ANY PART OF YOUR CUP HOLDERS ON FIRE. Take it slow. Remember were you took your screws out. Remember how your springs went back in. Take plenty of pictures. Not only did I bend my tabs back in by heating them up, I epoxied them as well to make sure it holds.
    What Lux doesn't explain above in detail is taking both lids out of each. They are a pain if you don't know how/were the springs came out and how to put it back together. You also have to take apart the heated/cooled part to get the door apart...
    I took the chrome pieces off the doors and put them on my lids as well. If you try to do this be careful as you will need to break the tabs that are underneath and epoxy them to your current lids.
    If your going to do this, please, please, and please take your time and be careful
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Here's some daytime pictures since I did this at midnight last night...
    Closed...
    Open with Driver heat on and Pass cool on (So you can see the LEDs)
    Oct 2008
    Long Island
    29
    1,363
    Nathanjax,
    You are missing the rubber bump stops and the spring loaded fingers to hold the cup against the plate. The rubber bumpers are the SAME as your stock cup holders so simply pull them out and push them in the new one. I have 1 left over if you need it (mine only came with 1 on eBay). Also the finger things are going to be VERY hard to find! Mine only came with one stock one and a makeshift piece of metal. It seems these are very easy to lose because any tight drink (vitamin water) which basically just fits in there..... when removed, the fingers pop out with the drink. But you definitely need them because soda cans and coffee will not touch the hot/cold plates without em.
    Oct 2008
    Long Island
    29
    1,363
    These are the rubber bump stops from the stock cup holders your missing.
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Quote Originally Posted by luxurylife33 View Post
    Nathanjax,
    PM'ed
  16. #14
    CEPMAN is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Escalade ESV
    Jul 2009
    NC, USA
    36
    360
    AWESOME!!!!!
    I'm definitely doing this mod - my vote for a sticky!!!
  17. #15
    McLovin Guest
    It is not easy to find these from a Platinum, nothing on Ebay at the moment. If anyone has this for sale let me know. I want to do this.
    Thanks
  18. Remove Advertisements
