'03 Problems - HELP!
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, '03 Problems - HELP! in Cadillac Escalade Forums; Hi everyone, I am a new member here and I just recently purchased an 2003 Escalade with 9200 miles. I ...
    jprek is offline Cadillac Owners Member
    Aug 2004
    3
    Hi everyone,
    I am a new member here and I just recently purchased an 2003 Escalade with 9200 miles. I now have almost 17,000 miles.
    I NEED HELP! Here is a list of problems I am having:
    1. I have a rattle when I go from stop to start. I took it to the dealership I bought it from. (It was a chevrolet dealership that my best friend owns). They replaced the muffler siting that it had "bad baffles" in them causing the rattle. When I got it back, the rattle was gone. After a few weeks, the rattle slowly came back. Does anybody know what the deal is or what it is?
    2. Clicking sound (like a rolling odometer) comming from vents. The sound is only occasionally. It goes away if I shut the climate control off.
    3. The "Service Stability" message came on. Is that bad?
    4. I feel my shocks are going. I have noticed a change in how the car handles bumps since I bought it. I haven't hit anything or drove hard. Is this normal.
    5. Pump noise comes on when car started sometimes. I'm not sure if this is a problem, I think it maybe the hydraulic leveler. It only lasts a few seconds. Is this normal?
    I would love to hear if this is normal or if they are problems. I used to have an '01 330ci BMW and I never had a truck before.
    PLEASE HELP! I would like to know of any notorious problems and/or tips for me. Thanks for the help guys.
    Jimmy
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,291
    Re: '03 Problems - HELP!
    Quote Originally Posted by jprek
    Hi everyone,
    Jimmy
    You will get a "air pump" noise a few seconds after starting, that is the air ride in the rear pumping up, that is normal. I have an 03' with 17k miles and my shocks feel the same as the day I purchased my truck, they give a nice tight ride. My "Service Stability" light comes on about once a month for a few minutes, but when looking for codes with the Tech II scan tool there is none, not normal but the machanic from the dealer said many Escalade's have this issue. I have no rattles or clicking sounds, I am very happy with the truck so far
    outofdablue is offline Cadillac Owners Fanatic
    May 2004
    Philadelphia
    411
    The noise from the vents might be leaves stuck in your vents. Especially if it onl.y happens when the fan runs. That other noise from your rear is normal, the rear suspension leveling out. The check stability light I get also from time to time. And as far as the other rattles, well an Escalade doesn't have the same fit and finish as the Beemer so that is pretty normal.
    MEJIA's Avatar
    MEJIA is offline Cadillac Owners Enthusiast
    Aug 2003
    MONTERREY, MEXICO
    34
    545
    Here is what is causing the rattle
    http://www.cadillacforums.com/forums...ead.php?t=9835
    Hope this helps,
    Mejia
    03whiteext's Avatar
    03whiteext is offline Cadillac Owners Member
    Jan 2004
    colorado
    44
    53
    my Service Stability light issue was solved by replacing the steering sensor that is inside the steering column, my dealer said he has replaced quite a few of them. my muffler popping was solved by installing a set of flomasters.
  8. Remove Advertisements
