02 Ext idle drops to 300 at times
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 02 Ext idle drops to 300 at times in Cadillac Escalade Forums; I would like it to stay at 500. But sometimes when i first start it up and back out of ...
    mnext02 is offline Cadillac Owners Fanatic
    316
    I would like it to stay at 500. But sometimes when i first start it up and back out of the drive way (or pull ahead from a parking spot) it kinda jerks cuz it drops down to 300 rpm and then back to 500. What would cause this?
    bhood23 is offline Cadillac Owners Member
    Dec 2003
    Penn Valley, CA
    39
    17
    Re: 02 Ext idle drops to 300 at times
    There is a TSB out for this. Go to your local Cadillac dealer and have them re-flash the ECM with the updated program from GM. Mine did this as well until it was re-flashed and now it idles and drives great.
    Machine's Avatar
    Machine is offline Cadillac Owners Fanatic
    Oct 2003
    Texas
    148
    The beginnings of a coked up Throttle Body could cause these symptoms. Mine use to do the same thing but with more frequency. It would dip down to 300 and then back up. For $5 and 15 minutes you could clean the TB and see if that's the fix
    Dec 2003
    Penn Valley, CA
    39
    17
    The dealer mentioned that could have been the problem as well with mine, but when they looked at the throttle body for any kind of build up, they did find any.
    T_Dogg8's Avatar
    T_Dogg8 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade EXT 2003 CTS
    May 2004
    PA
    2,860
    i get the same problem every once in a while. it's not too often, so it must be just the begining.
    Machine's Avatar
    Oct 2003
    Texas
    148
    When I first cleaned mine it too looked pretty clean but once I finished it ran like a champ. Give it a try. The worst that could happen is that you now have a clean TB. Just make sure you get a TB cleaner that's safe for all coatings. You have a Teflon coating that's sensitive to harsh cleaners like carb cleaner. Any auto store carries TB cleaner for all surfaces. Good luck.
    T_Dogg8's Avatar
    May 2004
    PA
    2,860
    maybe i should give that a try. can't hurt.
  10. Remove Advertisements
