Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: 2002 Climate Control Bulbs Replacement
09-11-09, 09:37 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | 2002 Climate Control Bulbs Replacement Had the dashboard apart last nite to finish my remote start install and fix my key cylinder switch so it turns to ACC position without wisegrips, I decided while being there to start fixing the lights issues in the dashboard. Also need to replace the ones in the power mirror, radio, URPA switch and lights switch. But all of the ones in the climate controls were out, so I decided to go with that one first. Others to follow this week...
First thing is to remove the dash trim piece. Tilt steering wheel down, ignition on, shift lever in 1st gear to give you more space to remove the trim. No screws, just pull it out. Squeeze the tabs at all 4 corners to get the control outta there. Plug was a bit tight in there, only the top lock hook to push and pull to remove. Then remove the 3 control knobs. They are a bit stiff, try to avoid using tools as this will most likely damage the area around.
Next remove 4 1/4 hex bolts in the back to separate the unit in half.
Inside there's 2 more hex screws to remove. You then want to separate the 2 control panels from the white plastic back piece. I managed to do so by gently prying apart the rectangle and using a small screwdriver to pull up on the unit. Once that's out, squeeze the plastic white pins from the PC board side to separate the white control panel where the bulbs are from the other one (pull out on the control plug). You should have this piece by itself as a result.
I used VW dash lights that I modded for this application. I would advise to use the proper bulbs, but I'm cheap and I got a bunch of those on hand and they are brand new. Using long nose pliers to pull out the 2 contacts from the plastic bulb holder, then cutting the metal piece off with good cutters. The bulbs are welded in place, but its a very accessible area, no other critical components are close by so no need to fuss about too much heat or messing up something else by adding too much flux or solder. Its a good practice weld for those of you who don't get to do this often. Finished result ready to reassemble:
Took about 30 minutes to complete, bulb intensity is just a bit less brighter than the dashboard lights. Complexity level is about half 6 pack (easy).  |
09-13-09, 10:57 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | Re: 2002 Climate Control Bulbs Replacement I realized the next day that the 4 climate controls buttons (AC, RECIRC ON-OFF, DEFROST) also have lights in em! I replaced the bulbs with VW ones again, but those are too big, they won't allow the button to move after install (but they do light up nicely...) Will have to hit the store and buy some smaller bulbs, which will be needed for the radio anyways. Pic of the panel:
Next on the list was the power mirrors bulbs, 2 hiding in there, same procedure, job was a bit more challenging as there's a lot of harware around the weld area, and those bulbs need to be welded over and under the board.
The URPA button was a different story, also 2 bulbs in that one, but in order to unweld them from the board, you have to take apart the switch, which is spring loaded. I've never had much luck with anything involving springs, so I cut the old bulbs off and welded the new ones on. Finished product seen here:
My headlight switch was also not lighted. Taking it apart I noticed that the single bulb in it is removable. At last, all is not lost at GM, this one will be easy to fix.... NOT! Even if the bulb is removeable, it is not available separately!!! Geeezzzz. So I modified that one to and replaced the bulb with a new one (replacement in the picture). OEM one had a blue cover on it, I'll try and stick that one on top (now it shows the light switch is a different color than the others).  |
09-14-09, 12:31 AM
| | Cadillac Owners Member Cadillac(s): escalade | | | | | Re: 2002 Climate Control Bulbs Replacement what size bulbs are in the a/c unit where can i get them? |
09-14-09, 07:51 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | Re: 2002 Climate Control Bulbs Replacement I'll try to post a pic tonight of the 2 models. The ones for the controls you can get by with slightly longer or bigger, there's room to fit, but not so much with the buttons. |
09-14-09, 10:10 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | Re: 2002 Climate Control Bulbs Replacement Pics of the bulbs with and without the plastic holder (which is not needed). I'm gonna get mine at an electronic store where I get my stuff for fixing pinball machines. They got all kinds of 12V bulbs of all sizes. One could even get creative and get a different color?
Larger ones are 0.420" lenght X 0.182" diameter.
Smaller ones are 0.231" X 0.118".  |
09-15-09, 02:01 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV | | Join Date: Feb 2003 Location: Winnipeg, MB | | | Re: 2002 Climate Control Bulbs Replacement I have never seen so many burnt out dash lights in my life! |
09-15-09, 09:23 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | Re: 2002 Climate Control Bulbs Replacement I agree, it would have been faster to mention the ones that are not burnt! 130K miles on the truck. |
09-16-09, 06:00 PM
| | Cadillac Owners Member Cadillac(s): escalade | | | | | Re: 2002 Climate Control Bulbs Replacement thanks for the info |
09-22-09, 11:03 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | Re: 2002 Climate Control Bulbs Replacement The next day after doing the power mirror bulbs, gf takes the truck out of the garage and the mirrors don't slide out anymore! The solder ran a bit on the underside and was causing the switch to be non-op! Good news is this didnt break any components on the switch, just a little cleanup and reinstall. Pic of the underside of the power folding mirror switch assembly.  |
09-26-09, 09:02 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac Escalade | | Join Date: Sep 2007 Location: Birmingham Age: 24 | | | Re: 2002 Climate Control Bulbs Replacement would love to change all the bulbs in my 02. A few bulbs have burnt up in my climate control, and a few others.
I would love to do all the dash lights and speedo/tach/gauges with a nice blue color.
I have no idea where I would get those bulbs though |
09-26-09, 11:35 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | Re: 2002 Climate Control Bulbs Replacement I got a bunch of small 12V bulbs and different color LED's this week at my local electronics store, will try to install LEDS in the 4 buttons of the climate control module. $15 for over 25 different models and sizes, pretty cheap! Will post pics of the results. |
11-11-09, 02:09 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | Re: 2002 Climate Control Bulbs Replacement Wow time flies! I finally got around to replacing the bulbs for the 4 buttons in the climate control unit. Instead of using bulbs, I replaced em with led's. Worked out pretty good!
Next on the list was to disable the ABS light from the cluster (since my EBCM is on the permanent disabled list). Taking apart the cluster is a pretty easy job.
Front cover comes off by prying a few tabs, same story for the back.
PC board is taken off by gently prying the contact points of the different guages. Easy does it!
I was happy to see that the bulbs were removable... But not the one for the ABS! Its a soldered in LED, #10 on the pic. Got it out and finally no more lights on from the dashboard while driving!
I also took apart the radio as only one light is still alive in there. I ran out of bulbs!!!! This unit has a lot of em, I replaced 6 and will continue next time around. I also want to replace the lights in the steering wheel controls.  |
11-11-09, 02:32 PM
| | Cadillac Owners Fanatic Cadillac(s): Escalade | | Join Date: Jul 2008 Location: Elmhurst, IL Age: 30 | | | Re: 2002 Climate Control Bulbs Replacement Hell it may be easier to fly you in than to ship all the parts out... Looks fun but not really my cup! Great pics and write up. |
11-11-09, 05:24 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2002 Escalade AWD | | Join Date: Nov 2008 Location: Québec, Canada Age: 40 | | | Re: 2002 Climate Control Bulbs Replacement No prob! Next day shipping is pricey! You might want to keep an eye on ebay for a cheap replacement. If the bulbs are ok in it use that one or send it thru regular mail. |
11-11-09, 05:32 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV | | Join Date: Feb 2003 Location: Winnipeg, MB | | | Re: 2002 Climate Control Bulbs Replacement Sk7 what type are the bulbs on the cluster that are removable? I have one out. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
