I recently changed the rear brakes on my 2006 ESV. I put a set of new rotors and pads so i was starting fresh since the old rotors had been re-cut already once. Now every time I hit the brakes, they makes this horrible squealing sound. I thought maybe they were a little dirty (cleaned all the parts with brake cleaner before installing them) so I hit them with some more brake cleaner last week. Still squeaking. Anyone have any input on this?
Had a look at the service manual, not much info on squealing brakes... I found there is a proper orientation of the brake pads for even wear that I didnt know about, but that's for 2WD models. I replaced mine recently, including park brake shoes, no special issues. I would check the backing plates. Maybe they are just a little close to the disc and make contact upon braking? Did the pads come with noize shim pads? Was the edge of the leading end of the pad filed at an angle? Nothing worse than squealing brakes to attract unwanted attention from pedestians!
UPDATE- I removed the shims that came with the pads, took the pads off and cleaned the backing and sprayed them with some permatex brake quiet spray. It helped, but not enough. Just to mention I installed new EBC sport rotors (dimpled and slotted) and a set of EBC Green stuff 6000 pads. Anything else I should check?
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
