People with Giovanna or any other sort of aftermarket rims.....
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, People with Giovanna or any other sort of aftermarket rims..... in Cadillac Escalade Forums; Do you guys/gals roll on your aftermarket rims in winter or do you swap back your stock wheels? If you ...
    Clem is offline Cadillac Owners Fanatic
    Jul 2004
    Edmonton, Alberta Canada
    40
    102
    If you keep them on through the winter how has the finish held up?
    Curious as I may be buying an 02 Escalade and was thinking of Giovannas and am not quite certain if I should keep them on over the winter or hold on to the stock wheels for the winter time.
    PistolPreeth's Avatar
    PistolPreeth is offline Cadillac Owners Fanatic
    157
    Re: People with Giovanna or any other sort of aftermarket rims.....
    I have 24 inch Giovanna Genoas. For the winter i go back to my stock rims. Its ok to drive through the snow in like 1 inch of snow with the 24s, but u still will be slippin and sliding. Performance tires and snow=not a good mix. Its not a big deal to put the stock wheels on. Pluis u can always opt for the factory chrome rims---so u wont be so (non baller) in the winter
    outofdablue is offline Cadillac Owners Fanatic
    May 2004
    Philadelphia
    411
    I think it all depends on the type of weather in your area. If you get any snow at all then definetly keep the stock ones on. I have had chrome tarnishing problems with my Foose wheels. On my rear passenger side, the rim started to tarnish and all the chrome came off leaving only the brass colored nickel finish underneath. The problem is the salt and all the chemicals they use to clear the snow. Also, that side is where the exhaust lets out and with the salt and snow + the steam and heat from the exhaust turned my bright chrome rim to copper color. And that was the only one I had a problem with, that makes me believe the gases from the exhaust had something to do with it. For the money you pay for those rims, it is worth the extra time and money to put the Oem's on in the winter. That way you can clean them, wax them and save some tire tread in the winters.
    brett79's Avatar
    brett79 is offline Cadillac Owners Fanatic
    Apr 2004
    38
    278
    I would definitely suggest swapping off your wheels during the winter. The salt eats away at the chrome.....I am taking my 22's off this winter. Last winter I had a Navigator with 20's and decided to leave them on (mistake), and I am not gonna make it again!
    Jungle George's Avatar
    Jungle George is offline Cadillac Owners Fanatic
    Mar 2004
    Los Angeles, CA
    136
    Quote Originally Posted by Clem
    WINTER???? Different rims???? Here in SoCal we use the same rims all year round without fearing problems....
    Jul 2004
    40
    102
    Thanks for the insights.
    I pretty much figured swapping them for stock in the winter would be a better idea than leaving them on.
    As for looking not so baller in the winter. Not really worried about that either since when I was driving my BMW in the winter (before it became a garage queen) I rolled on 15" steelies. That kinda stuff really humbles a man.
    157
    heres a question....
    the stock chrome wheels. are those ok to drive with in the winter? will the salt eat at them? I mean they are chrome....aren't they?
    blingblingcv's Avatar
    blingblingcv is offline Cadillac Owners Enthusiast
    746
    I think its fine to drive in the snow with chrome wheels as long as you maintaine them. I have used my rims in the snow for three years now. I did however get them washed alot and washed them myself. I would only recommend doing this if you have a garage. Because of the cold weather, leaving your rims out in the cold for a long time will make them start to crack. My college roomate had 23" giovannas on and because he kept his outside his rear right wheel got frozen and cracked once he hit a pothole. This made him have to put his spare on. Now having a spare and 3 24" wheels, will mess up the wholew drive. He had to go to a local rims store and pay 1500 to get a new rim and tire.
    157
    so even the stock chrome rims are not cool to use in the snow?
    746
    I do not have the chrome stock wheels. But they are chrome, so I guess the salt that is put on the road will mess up the chrome. But you have 24" giovannas so who really cares. If you do roll through the snow in chrome wheels. I recommend you whipe them down when you are done driving because salt chrome do not like one and another.
    2004 is offline Cadillac Owners Member
    Mar 2004
    44
    Quote Originally Posted by Jungle George
    I heard that. I roll South Texas and SoCal w/ same rims all year. I've never seen it snow.
    99escalademan is offline Cadillac Owners Enthusiast
    Minnesota
    545
    Doesnt it mess up your suspension? usaully stock oem rims are 17" or 18". So your on 24's or whatever for 7 months and and 4 months on a smaller size rim.
    Jul 2004
    40
    102
    Well you usually try to keep the same wheel/tire package height.
    for example: a 225/50/16 will be approximately the same height as a 235/35/19 +/- 0.5"
    You can usually get away with a +/- 3% variance
    By keeping the total height the same you should not affect your suspension, speedo etc...
    The only think that SHOULD change is your acceleration due to heavier wheels and larger rotational mass.
  16. #14
    brett79's Avatar
    Apr 2004
    38
    278
    Stock chrome rims could get ruined too. Like someone mentioned on here, as long as you keep them clean the you will be ok (as for any chrome wheel). I just found it a pain washing my wheels all the time and got lazy, and that is when my wheels got messed up. The stock wheels are much smaller and much easier to clean.....plus in the winter with them on, I wouldnt mind just running my Lade through a touchless carwash to get the salt off....
  17. #15
    Jul 2004
    40
    102
    Forgot to add that the ride may be rougher due to the smaller sidewall.
  18. Remove Advertisements
