| Re: '00 Escalade rebuild I don't mind giving you some advice (altho I'm no expert). My last similar project, rebuilt of 1991 full size blazer K5, costed over a 2 year period over 20K$! All this witout really realizing how much I had put into it. When u start modifying stuff, and you want to do it right, there's always a lot of unexpected expenses that appear along the way... Reboring the engine is not too bad, if you keep the OEM injection, just might require adjustements or maybe bigger injectors or ? Check out the full size chevy forums (fsc.com), I'm sure its been done there before. Same for the tranny, its an easy swap if the TCM's can be swapped as well and plug into the same harness. I've done many VW swaps, its a you know when u start it project and your bank account tell u when its over... Good luck! |
