| Re: 2002 Esdcalde stalling occasionally and rough idle Its 99.9% the throttle body,for some reason i am only seeing this problem in 02s. So clean the heck out of it but avoid directly spraying cleaner directly into it, it might give you a minor start up problem. when you clean it pay attention to the rim of the throttle body. and also the walls. if you want to remove it to really get in there, you can, just know you will have to buy a new gasket and torque the bolts back on.cleaning its a very simple procedure with big results. And be careful if you gonna clean your MAF, its very delicate and damage will throw your air/ fuel ratio off. Still, i dont think there should be a reason to clean the MAF sensor unless its visibly dirty maybe from having a Cold Air Intake. |
