Mc Gaughys drop?
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Mc Gaughys drop? in Cadillac Escalade Forums; what i have been told is that the 3/5 deluxe kit from mc gaughys can only be used in your ...
    TwEnTy4InChEsTrOnG's Avatar
    TwEnTy4InChEsTrOnG is offline Cadillac Owners Member
    Jul 2004
    Thousand Oaks, CA
    29
    24
    Mc Gaughys drop?
    what i have been told is that the 3/5 deluxe kit from mc gaughys can only be used in your escalade if you have 2wd..and would my 24s fit with this kit..has anyone done this kit on their lade..if so post pics and some info about this drop...also some pics with the 2/3..thanks alot.
    invincible569 is offline Cadillac Owners Member
    Feb 2004
    87
    Re: Mc Gaughys drop?
    Do a search for infamouslade's Escalade on 24's and the 2/3 drop he put on. It looks very nice!!
    T_Dogg8's Avatar
    T_Dogg8 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade EXT 2003 CTS
    May 2004
    PA
    2,860
    a 3/5 drop and 24s would probably be too much. i believe you'll get at least some rubbing with a 2/3 drop, so a 3/5 would be a lot worse. if you want that much drop, get air bags.
    ctozzi's Avatar
    ctozzi is offline Cadillac Owners Member
    Automobile(s): 2007 Esco on 22's
    Las Vegas
    39
    i'm thinking of the same thing on mine, but it's awd. So from what I've heard its only for 2wd's. Good luck
    ctozzi's Avatar
    Las Vegas
    39
    i got 24's and the 2/3 kit and no rubbing and rides like stock cost $ 825 installed. If i could load a dam picture here i'd show ya.
    Jungle George's Avatar
    Jungle George is offline Cadillac Owners Fanatic
    Mar 2004
    Los Angeles, CA
    136
    Mine has the 2/3 deluxe drop, spindles in front and new springs in the rear...
    jamesmbond is offline Cadillac Owners Member
    49
    I just had my Ground Force drop kit removed and replaced with the McGaughys 2/3" kit. The ride is MUCH IMPROVED and now is softer more like the stock Escalade rode. The Ground Force 2/3" drop kit (torsion keys in front and springs in back) made the Escalade ride like crap.
    My only problem now is that the McGaughys kit does make the front ride even lower (by about an inch) than the Ground Force so I get rubbing inside the fendor well even when hitting small bumps in the road.
    I get a little bit of rubbing when turning sharp in the parking lots but the fact that the tire can travel right up into the fendor well worries me--hitting a bump at high speed (50mph +) sounds like it'll tear up something when they hit the fendor well.
    Any suggestions or experience on this from anyone.
    JB
    T_Dogg8's Avatar
    May 2004
    PA
    2,860
    what size wheels and tires?
    49
    20" Boze wheels with 20" x 10" Toyo tires.
  12. Remove Advertisements
