popping in the front diff.
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, popping in the front diff. in Cadillac Escalade Forums; I have 03 ext with just over 13,500 miles on it and it has a popping in the front end ...
    03whiteext's Avatar
    03whiteext is offline Cadillac Owners Member
    Jan 2004
    colorado
    44
    53
    Unhappypopping in the front diff.
    I have 03 ext with just over 13,500 miles on it and it has a popping in the front end when I turn,I take it to the dealer today and they pull out the front axle drain plug and it is full of metal shavings,they say they will have to pull the frontend out and split the cases to see what the probem is. has anyone else have this problem? I'll keep you posted on what they tell me, they said they should know by tomorrow.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    Re: popping in the front diff.
    I have not heard about any front gear problems in any of the GM truck boards, let us know what they find
    03whiteext's Avatar
    Jan 2004
    colorado
    44
    53
    after opening it up a bearing was the source of the shavings, they replaced all the bearings and seals and it is still making the same noise. they are not sure what it is now. well at least they got a me rental while it is in the shop, it looks like its going to be a while.
    MEJIA's Avatar
    MEJIA is offline Cadillac Owners Enthusiast
    Aug 2003
    MONTERREY, MEXICO
    34
    545
    Quote Originally Posted by hcvone
    I will be thankful if you post what the dealer tells you about the problem of your truck.
    Thanks,
    Mejia
    03whiteext's Avatar
    Jan 2004
    colorado
    44
    53
    they are now saying it is the rubber bushings in the shock tower's, they are on order i'll let you know if it solves the problem.
    03whiteext's Avatar
    Jan 2004
    colorado
    44
    53
    after 8 visits and thousands of dollars in warranty work, the popping while turning delima has been solved with a .5 cent, 1/8th. inch washer between the body and front left body mount.
    caddypimpin is offline Cadillac Owners Member
    Oct 2003
    17
    is it whenever you turn the wheel all the way......... my 03 makes a clicking noise when ever i turn the wheel alot............its a loud click in either direction... i cannot figure it out......... its a clicking/ poping noise that can be felt.............. what should i do?? does this sound like the same problem??? i am worried that my dealer will not tell me about the shaving if i have the same problem........... they are very shady...........
    fRiSkOcAdDy is offline Cadillac Owners Member
    Automobile(s): Escalade
    Nov 2003
    20
    I would like to know this also...
    03whiteext's Avatar
    Jan 2004
    colorado
    44
    53
    that sounds like the same problem i had.you could feel it right at your feet, have them call tech.support and mention to them about the washer on the front body mount and they should talk them through it,that is what my dealer did.
  12. Remove Advertisements
