Temperature Is Running High And Air Conditioner Is Blowing Cool Air But Not Cold
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Temperature Is Running High And Air Conditioner Is Blowing Cool Air But Not Cold in Cadillac Escalade Forums; Help!!!!!!...
    PACMANEJ is offline Cadillac Owners Member
    May 2004
    MONTGOMERY, AL
    12
    Help!!!!!!
    joshuap is offline Cadillac Owners Fanatic
    Automobile(s): Escalade EXT
    Apr 2004
    196
    Re: Temperature Is Running High And Air Conditioner Is Blowing Cool Air But Not Cold
    If you are speaking about the temp guage in the mirror, apparently Cadillac does not care. My father's is often off up to 9-10 degrees and Cadillac says it is working in proper specs to be off 10 degrees. My father bitched and told them that they are just waiting for a lawsuit when the gauge reads 41, and it is really 31 out...He told them not even to put the damn thing in if it is that much off...
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    In the summer time if your sitting in traffic your temp will read higher, the sensor is next to the radiator, but when moving it should read pretty close to the right temp.
    Apr 2004
    196
    Nope, this is while driving at 65 mph! We have seen several temperature signs, which show the temp to be consistently high. My truck does the same thing. I could understand if we were sitting still, but that just isn't the case.
    T_Dogg8's Avatar
    T_Dogg8 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade EXT 2003 CTS
    May 2004
    PA
    2,860
    i wouldn't always believe the temp. signs on places like banks. they're never right. mine is pretty close to always right on.
    Apr 2003
    13,280
    TD is correct, we have 2 banks with temp display, believe it or not they are usually 8 degrees apart in what they display. You might want to check your temp sensor, it is up near the passenger headlight assy, mine had popped out of the hole it sits in and that caused it to have some strange temp readings, it was resting up next to the radiator, and I had a customers car that it was almost dragging on the ground. You have to pull the grill off to see it, and that is only a 5 minute job.
    slk230mb's Avatar
    slk230mb is offline Moderator
    Automobile(s): Now: 2008 STS-V, 1960 Eldorado Brougham Then: 2002 Escalade
    Feb 2004
    Bayside, NYC
    31
    5,826
    Last summer mine was broken, it was a wet and damp 60* day and the car said 125*, the sensor was shot, and since its been replaced, dead on temps for me.
    ~Steve
    Daryl in KY's Avatar
    Daryl in KY is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade
    Jan 2004
    Western Kentucky
    65
    159
    What year is your Lade? My '00 seams to do the same thing, but I don't believe it's the AC. You can get a thermoniter in most larger parts stores to check the air temp coming out of the vents. Normally the AC temp is around 60 degrees when set on Max. When it's hot out and the interior is at 100+ degrees, it takes a while to cool all that leather down.
    Sta11ion is offline Awaiting Email Confirmation
    Apr 2004
    Toronto Ontario, Canada
    39
    218
    I Have Had Terrible Experience With My A/c, On Idle It Is Not Cold Sometimes It Works Other Times It Doesnt. It Is Never Cold Enough, I Will Be Bringing It For Service For The Second Time At Royfoss.in Toronto
    T_Dogg8's Avatar
    May 2004
    PA
    2,860
    so far mine has worked like a champ. i don't use it a lot, but when i have, it works great.
  13. Remove Advertisements
