How do I remove door panel???
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, How do I remove door panel??? in Cadillac Escalade Forums; Does anyone have a diagram on removing the driver side door panel? Thanks...
    jrs05caddyext's Avatar
    jrs05caddyext is offline Cadillac Owners Connoisseur
    Automobile(s): Escalade
    Jul 2005
    SO. CAL
    32
    1,584
    ESCALADOR's Avatar
    ESCALADOR is offline Cadillac Owners Fanatic
    Mar 2008
    Manassas City, VA
    246
    Re: How do I remove door panel???
    this is 2005. hope it helps
    # Remove the door handle bezel. Refer to Handle Bezel Replacement - Inside .
    # Remove the door trim panel upper extension. Refer to Trim Panel Replacement - Upper Extension .
    # Using a suitable flat-bladed tool, gently pry the manual lock lever from the door trim panel.
    # Remove the push in fastener (3) at the front edge of the door trim.
    # Remove the cap (5) covering the screw on the rear edge of the trim panel.
    # Remove the trim panel screws.
    * Remove the screw (2) from within the opening where the manual door lock lever resides.
    * Remove the screw (4) from the opening in front of the armrest.
    * Remove the screw (6) from the rear edge of the trim panel.
    # Carefully slide the trim panel (1) up in order to release the retainers from the door.
    # Disconnect the electrical connectors.
    Jul 2005
    SO. CAL
    32
    1,584
    Thanks
    klipsch21 is offline Cadillac Owners Member
    Jul 2009
    27
    12
    not sure what year escalade you have but I found this guide for a 99-00 on how to remove the door panel.
    fixpal.net/escalade/front_door_panel/
    92WHTSTS's Avatar
    92WHTSTS is offline Cadillac Owners Fanatic
    Automobile(s): 99 Eldorado ETC
    Jan 2011
    277
    Wish someone had the same illustration for a Eldorado, I need to fix some broken clips.
    roketsciontist is offline Cadillac Owners Member
    Aug 2014
    thanks for the instructions
    javdog is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    10
    good info
  10. Remove Advertisements
