Navigation while driving
Page 1 of 7 1234567 LastLast
Results 1 to 15 of 102
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Navigation while driving in Cadillac Escalade Forums; I have a 2006 Escalade with factory navigation. Is there a way to modify the system to be able to ...
    ab8081 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    6
    I have a 2006 Escalade with factory navigation. Is there a way to modify the system to be able to use the nav while driving? Have to stop to change address now and it's a pain!!
    obxdiver is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV Platinum
    Dec 2008
    Portsmouth, VA
    56
    219
    Re: Navigation while driving
    Yes, Its simple
    You have to cut a small wire (green/white) connected to the back of the radio
    This is the "Vehicle in Motion" signal to the radio.
    You remove the radio, clip the wire from the plug, and put the radio back in.
    That's all.
    It took a total of 10 minutes for me to do from start to finish.
    Nov 2007
    6
    Thank you. I'll try it tomorrow
    jdjd is offline Cadillac Owners Member
    Aug 2008
    7
    Did this really work? Is it as simple as that? Have you actually done this and it worked with no problems? Thanks...
    Dec 2008
    Portsmouth, VA
    56
    219
    Done it. Worked like a champ.
    I can enter addresses at 60MPH
    Clip the wire in the RED box shown below
    Rcaddy is offline Cadillac Owners Member
    Automobile(s): Escalade
    Mar 2009
    15
    Same procedure for the 04?
    Also going to run video on the Nav screen. I've read the posts on how. Do you know if I can pull the video signal from the RSE however.
    jordan00escalade is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 Escalade, 2002 Deville DTS
    Mar 2005
    Bay Area, Ca.
    41
    974
    Will doing this effect any other monitoring systems?
    Dec 2008
    Portsmouth, VA
    56
    219
    Yes, it will be the same wire and pin on the 04. I just checked it for the 04, and it is the same as my 05.
    Don't know about the video signal from the RSE.
    Dec 2008
    Portsmouth, VA
    56
    219
    Quote Originally Posted by jordan00escalade View Post
    None. Everything still works as designed, except you dont have to stop to enter destinations.
    All touch screen button work when the truck is moving.
    whosurpopi is offline Cadillac Owners Fanatic
    Nov 2008
    120
    Just to chime in, I just finished doing this to my truck, and love it. Thanks OBXdiver.
    Nov 2007
    6
    Me too! So simple and it works in literally 10 minutes.
    Thanks again obxdiver
    Dec 2008
    Portsmouth, VA
    56
    219
    I was glad to have helped.
    These forums are a wealth of info. This thread just adds to it.
    Please don't wreck your Escalades trying to put in addresses while u drive.
    Nov 2008
    120
    My volvo lets you use while driving, yet the cadi and Jag dont let you. (volvo and jag were both ford products)
  16. #14
    d-dash's Avatar
    d-dash is offline Cadillac Owners Fanatic
    Automobile(s): '04 Escalade EXT
    Oct 2005
    Des Moines, Iowa
    34
    352
    Quote Originally Posted by Rcaddy View Post
    http://www.cadillacforums.com/forums...interface.html
    I just set up the nav tv like in the link posted and am using the video from my rse. It was actually quite easy to set up. All you need to do is tap into the dark blue wire coming out of the dvd player. Attach that to the positive wire in an rca cable, and connect the negative to the dvd player chasis. then just run it up to the nav tool.
  17. #15
    Mar 2009
    15
    That info regarding the RSE is very helpful. I was curious about audio controls and functionality. So when the movie starts it just show up on the screen? What about those "mute" functions which are displayed. And what happens when you change the source. Does the video automatically disappear??
    I can totally pull this off. GREAT INFO.
  18. Remove Advertisements
