Navigation while driving - Page 6
Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 102
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Navigation while driving in Cadillac Escalade Forums; If you cut the WRONG ONE, I believe the right side of your audio system will be off...
  1. #76
    oldworld is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 Escalde, 2007 DTS
    Nov 2007
    Lancaster County, PA
    532
    Re: Navigation while driving
  2. #77
    ridetoyoudie is offline Cadillac Owners Member
    Automobile(s): Cadillac Escalade Base
    Apr 2008
    Queens
    59
    yeh thx obx I ****ed up the first wire hahaa i was almost sure i cut the wire but i cut it far enough back in case I ever wanted to splice them back together. Anyway when I went to cut it far back I mixed up the 2 green/white wires and ended up cutting the wrong wrong. No big deal I just spliced them back together, soddered them together and put a heat shrink tube on it so it shouldnt move. What does the other green/white wire control anyway (the one that is not suppose to be cut), I know it says "remote playback device right audio signal.." but what exactly does that mean? Thx again obx love the little mod now
  3. #78
    obxdiver is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV Platinum
    Dec 2008
    Portsmouth, VA
    56
    219
    So does this mean that yours is now working with the wire on C2 Pin E cut?
    You can enter addresses while driving AND the NAV is updating as it should?
    If so..... Good Job
    PS: As "oldworld" said, the other green wire is the right channel audio
  5. #79
    Apr 2008
    Queens
    59
    exactly hahahaa thxx obx gonna try out the navi tonightt
  6. #80
    big.eds is offline Cadillac Owners Member
    Apr 2008
    24
    anyone in orange county, CA wanna do his for me?
  7. #81
    Madmex is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Escalade EXT
    May 2009
    40
    4
    I just removed my radio on my 2005 Cadillac Escalade and my wire connector was not like the one on the diagram listed above. I don't have a plug small plug like the one indicated. I do have two plugs a large one and a smaller one and the pin that would be "e" is orange.
  8. #82
    May 2009
    40
    4
    I just removed my radio on my 2005 Cadillac Escalade and noticed I do not have the same plug type that is illistrated on page 1. I have two plugs a large one and a smaller one still bigger than the one listed earlier. The wire in the "e" spot on my plug is also orange so did not know if I should cut the wire. on the smaller plug I do have TWO green and white wires. Hhmmmm.
  9. #83
    d-dash's Avatar
    d-dash is offline Cadillac Owners Fanatic
    Automobile(s): '04 Escalade EXT
    Oct 2005
    Des Moines, Iowa
    34
    352
    it is the smaller plug, pin e iirc. If you look closely, the larger plug has a numbered set of pins i.e. a1,2,3... and b1,2,3... The smaller plug has the lettered pins.
  10. #84
    rayagrella is offline Cadillac Owners Member
    May 2009
    3
    I pulled my Nav unit from my 05 Escalade ESV and it has the large connector and the smaller one, but the smaller connector is actually a 24 pin instead of a 12 pin as shown. There are 4 rows of pins instead of 2. The lowest right 2 pins when looking at the connector have orange wires coming in. Anyone have any ideas? Thanks!
  11. #85
    May 2009
    3
    I cut a green/white wire on the back of my Nav. Everything still works fine as far as all speakers with music and the nav still works but I am not able to enter addresses while the car is moving. Has anyone had experience with a 24 pin connector instead of a 12 pin as shown in this thread on an 05 Escalade ESV with touch screen Nav?
  12. #86
    jperdigon is offline Cadillac Owners Member
    Automobile(s): escalade
    May 2009
    38
    10
    A Piece has been made but not release for 2006 and earlier navigation systems, navigation override and audio and video inputs, before you use to have to use the unlock piece plus a second piece that would give you audio inputs, now the piece is all in one, contact me for more info at goyex@hotmail.com it is sold i think for around $350.
  13. #87
    ross_g is offline Cadillac Owners Member
    Automobile(s): 2006 ext, 2005 srx
    Mar 2009
    Hampden Massachusetts
    47
    37
    This is an easy as pie mod all you need is a 7mm socket and a nut driver.
    The wireing diagrams are good but if you are like me pics are better. So i took some pics to help you all out.
    after u take off the dash bezel simply take out 3 7mm screws.
    pull out the radio and remove the 3 plugs
    then remove (or cut) the wire A simple terminal tool is available threw harbor freight it might be different then mine.
    tape off the wire and reverse the procedure to reassemble.
  14. #88
    May 2009
    3
    Thanks Ross_G. I opened her back up, reconnected the first green/white wire I cut and then cut the second one. The nav immediately allowed me to enter while I was driving. At first the nav did what others have said and it did not update for about every 10 seconds. After driving about 3 hours, it finally started updating real time like normal. Now it is perfect!
    Thanks for everyone's help. It was invaluable.
  15. #89
    jcgmu is offline Cadillac Owners Member
    Sep 2009
    12
    Thanks to all for this thread!
    It took me about 10 minutes start to finish after work yesterday, to pop the radio out, and snip the green VSS wire.
    It took about 5 miles or so on the way to work this AM to get the GPS work normal again (to quit updating every 15 seconds or so) and then it began to work like normal, except now I can add destinations in motion!
    I just wanted to reply back with a success story for anyone else searching for this thread...
  16. #90
    fouad is offline Cadillac Owners Member
    Automobile(s): Cadillac STS 2005
    Nov 2009
    37
    15
    Is that also possible with Cadillac sts 2005?
    Thanks alot
  17. Remove Advertisements
