Navigation while driving - Page 4
Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 102
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Navigation while driving in Cadillac Escalade Forums; Well I finally got it up and running. I had to add a on/off switch to turn off the speed ...
  1. #46
    mbovinet is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade ESV Platinum
    Nov 2008
    Nebraska
    94
    Re: Navigation while driving
    Well I finally got it up and running. I had to add a on/off switch to turn off the speed sensor wire so I could input my address while driving. Only issue is that the nav stops moving at that time. So it's not moving or updating all the time I've got the button pushed in. Once I turn it back on the nav starts moving and updating again. It then takes a small bit to get up to date on exactly where were at at that time. So. mine's not as cool as all of yours as it's an extra step and a delay but needless to say I can input an address at 70 just as long as my new destination is reached after the nav updates.
  2. #47
    obxdiver is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV Platinum
    Dec 2008
    Portsmouth, VA
    56
    219
    Good Job
    As stated earlier, they must have changed something in 2006 to stop this from working.
    Fine, then we will add a switch to turn it on and off.
    Is your switch a toggle switch or a pushbutton?
    I hope you put an on/off type rather than a momentary pushbutton.
    Hopefully you are trying to hold the button in with one hand while entering an address with the other!!
    Where did you mount the switch?
  3. #48
    Dec 2008
    Portsmouth, VA
    56
    219
    For some reason this forum will not let me edit the above message anymore. Something about 40 minutes have expired. Never seen that message before
    Anyway, I meant to say
    "Hopefully you are NOT trying to hold the button in with one hand while entering an address with the other!!"
  5. #49
    Nov 2008
    Nebraska
    94
    It's a standard on/off push botton switch. For sure not a momentary button. That would have been a pain. I mounted it on the drivers side bottom of the center console, nearest the bottom of the dash. I'll get a pic of it later today for ya. I just didn't want to add it into the main dash
  6. #50
    oldworld is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 Escalde, 2007 DTS
    Nov 2007
    Lancaster County, PA
    532
    Before I attampt............
    Does this hold true on an 03?
    Only with touch screen OEM unit, or the non-touch screen OEM unit as well?
    THANKS
  7. #51
    hotrod04 is offline Cadillac Owners Member
    Automobile(s): escalade
    Feb 2009
    68
    17
    Mine works great, first time.
  8. #52
    Dec 2008
    Portsmouth, VA
    56
    219
    Quote Originally Posted by oldworld View Post
    THANKS
    I just looked at 2003, and YES, its the same wire.
  9. #53
    Nov 2007
    532
    HAD SAME EXACT PROBLEM. I have an 03 NAV.
    Cut the wire....
    Hooked it back up.
    Able to enter address BUT, Nav locked up...shows same location....some 150 miles away.
    ANY HELP BEFORE I GO AHEAD A REATTACH THE WIRE??
    Thanks
  10. #54
    Nov 2008
    Nebraska
    94
    Cut the wire....
    Hooked it back up.
    Thanks
    You can add a $2.69 dollar on/off switch like I did and it works fine
  11. #55
    Nov 2008
    Nebraska
    94
    Here's the pic of the switch I installed
  12. #56
    G-lade is offline Cadillac Owners Member
    Jun 2006
    12
    i was looking for this wire on my 2005 lade but i did not find it i only found 2 green wires one only green and the other green and black on the big clip and 2 green wires on the small clip but no dark green with white on it so how can i figure this out
  13. #57
    Nov 2007
    532
    On mine, both the green wires with the white stripes were on the smaller connector. There was a diagram posted as to which one of the two to cut. If you cut the wrong one, the speakers on on side of the truck will not work....then its the other wire.
    My nav will also need the on/off switch like the one posted above in order for this to work.
  14. #58
    Rcaddy is offline Cadillac Owners Member
    Automobile(s): Escalade
    Mar 2009
    15
    OBX -
    You seem to know the electronics/wiring in the dash near the HU. Can you advise which wire I should tap for switchable 12v? I'm using it to power my NAV TV unit. I tapped on in the larger radio wire harness but it only sends 12volts when the hearlights are on.
    Thanks very much.
    Rcaddy.
    BTW - snipped the nav wire...no problem at all. It defaulted to a new "Zone" on the east coast but after I reset to my zone in the PNW it found me in no time flat...maybe 3 minutes.
  15. #59
    Dec 2008
    Portsmouth, VA
    56
    219
    I am not sure about which one is switchable 12 volts.
    I will post this picture of the full radio wiring schematic and see if it helps.
    The red box shows 12 volts with a note "Hot at all times" on the orange wire
    I can found the ACC/RUN/START schematics if that will help.
    Lets start with this drawing
    And here is the fusing of the ACC/RUN ignition switch.
    And one more of 12 Volt Power Distribution. This one may help you.
  16. #60
    Nov 2007
    532
    Hey MBO:
    Where did you get that switch? Does it illuminate?
    Lastly, what made you install it there and not higher up, say on the egde of the console....so maybe its alittle higher to reach while driving. Was there any reason to install it there?
    THANKS
  17. Remove Advertisements
