Navigation while driving - Page 3
Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 102
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Navigation while driving in Cadillac Escalade Forums; Originally Posted by mbovinet Yes, driving it a bit finally got it registered again and working normally. I then went ...
  1. #31
    whosurpopi is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2008
    120
    Re: Navigation while driving
    Quote Originally Posted by mbovinet View Post
    Yes, driving it a bit finally got it registered again and working normally. I then went back home and snipped the wire and tried it again. I drove it around for about 20 minutes and also stopped a few times to see if it would catch up to itself. Nope. Never did. I reattached the wire and drove up the street and again it was working properly again.
    It's just my luck
    That sucks. When I first did mine, it was like yours, but after a couple of minutes of panicking, it updated itself, and worked great.
    Maybe in Nebraska there isnt as many towers to update (I dont know anything about how the satelite systems work) and you just need to give it more time, or take it to a urban area.
  2. #32
    blkesv2004 is offline Cadillac Owners Member
    Automobile(s): 2004 escalade esv
    Mar 2009
    52
    25
    Thank you sooo much for this awesome tip!!! My husband cut my wire on yesterday. I can't tell you how many times in the last 5 years that I have had to pull over so that I or my passenger could set the address for navigation. This feature is wonderful to have but we have to treat it just like texting, don't do it while driving, allow the passenger to.
    Thanks again,
    J.
  3. #33
    obxdiver is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV Platinum
    Dec 2008
    Portsmouth, VA
    56
    219
    It's just my luck
    They must have changed something in 2006 to prevent this hack from working.
    Oh well. Glad its working again.
  5. #34
    ratbike1's Avatar
    ratbike1 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade EXT
    Aug 2008
    106
    Quote Originally Posted by obxdiver View Post
    Just to clarify... OBX yours is a 2005? If so I'll do this tonight!
  6. #35
    Dec 2008
    Portsmouth, VA
    56
    219
    Quote Originally Posted by blkesv2004 View Post
    Thanks again,
    J.
    This is indeed a great hack.
    I am very glad it worked for you.
    Did your NAV screen stop updating for a while like some others after you cut the green/white wire?
    I remember mine did this too but it started updating 5 minutes after I started driving.
    It's just my luck
    Mike, maybe try to cut the wire again, but this time drive the truck longer.
    Leave the wire cut for a day or 2 if u can live w/o the nav working that long.
    If it does not start working after that long, then you are out of luck.
    I would give it one more try.
    Once it starts updating again after the wire is cut, it never stops again.
  7. #36
    Dec 2008
    Portsmouth, VA
    56
    219
    Quote Originally Posted by ratbike1 View Post
    Yes. 2005 ESV Platinum
    Radio Option Code "UM8"
    Let us know if you have the screen update problem after you cut the wire.
    If so drive the truck around until it starts again.
  8. #37
    Mar 2009
    52
    25
    My NAV screen only took a few minutes to update, as a matter of fact, we didn't even notice anything but a little blink.
    Thanks again for the tip.
    I am glad that I have found this site!
    J.
    blkesv2004
  9. #38
    HamMan is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade & 1991 Allante
    Dec 2005
    34
    Is there an easy way for a do it your selfer to remove the radio?
  10. #39
    Dec 2008
    Portsmouth, VA
    56
    219
    Quote Originally Posted by HamMan View Post
    Press the emergency Brake
    Put the truck in the lowest gear
    Tilt the steering wheel all the way down
    Gently pull off the dash bezel by hand starting in the upper left corner and work your way to the radio
    Work the bezel off around the wheel and set it aside.
    Now, only 3 screws hold in the radio.
    Unscrew them and the radio slides right out.
    10 minute job.
    No tools are required to remove the bezel.
    It just snaps on.
  11. #40
    mbovinet is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade ESV Platinum
    Nov 2008
    Nebraska
    94
    I can give it another shot. I drive it about 20 minutes the first time. it did update 1 time and then froze up again and the GPS light stayed lit the entire rest of the drive. Then we went into dinner, came out and probably had another 30 minutes of drive and park time in it. 1 more update and froze up again. I then hooked the wore back up and within 2 minutes it was back to normal.
  12. #41
    Dec 2008
    Portsmouth, VA
    56
    219
    I guess you could hook up a switch to open/close the wire.
    Open to enter addresses
    Closed to make Nav screen update.
  13. #42
    Nov 2008
    Nebraska
    94
    I thought of that also. Just not sure on where to place the switch
  14. #43
    The Lac is offline Cadillac Owners Member
    Aug 2008
    34
    55
    I'm assuming this is the touch screen version right?
    I've got an '03 with a Delphi unit, and it's touchscreen. Will this work for me too?
    I don't want any issues with the nav system.
    Does it still show you how long until you arrive at your destination?
  15. #44
    Nov 2008
    Nebraska
    94
    Quote Originally Posted by The Lac View Post
    Yes, Mine is a Touch screen version
  16. #45
    Dec 2008
    Portsmouth, VA
    56
    219
    I just checked for the 2003 Escalade and YES, it is the same wire on that year radio.
    Connector C2, Pin E
  17. Remove Advertisements
